Old 10-17-2016   #11
Default Re: Whelp....it's that time for us in the north.
nope, more of before you pull the dash pad for a chime, verify you need the heater core too.. no sense taking the pad off more than needed
Concur. Too early in the assessment yet. You haven't answered the hoses question yet either
Old 10-17-2016   #12
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
If you smell coolant.
If the smell is in the passenger compartment with windows closed.
If you have a 25 year old heater core.
Then you would be wise to investigate it fully.
I will say again, it is becoming one of the most common repairs that we are making.
Most all customer complaints start out the same way.
" Months ago I started to notice an intermittent coolant odor".
The core costs under $150.00.
Replacing it before it damages all that lives down there would not be a bad choice.
Old 10-18-2016   #13
dredgeguy
dredgeguy's Avatar
I agree with Marty, ask me how I know......first was the smell of coolant, then the windshield fogged up. I found green streaking of coolant under the passenger side firewall. The heater core is not expensive but it is a job. Thanks to Wazoo group for doing mine last year during one of our maintenance days. It took 10 hours.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 10-18-2016   #14
Originally Posted by Regimof View Post
Ok.
So getting at said core is ... quite a project?
Yes Cliff posted up (Dynomite) a how do it from the underside vs. pulling the dash I suggest you look for that thread
The biggest joke in the C4 community is that GM Engineers designed the rest of the C4 around the heater core. Bluntly its a PITA job
Old 10-18-2016   #15
Default Changing the Heater Core WITHOUT Pulling the Dash
Replacing the Heater Core and Heater Hose Connection
Old 10-18-2016   #16
Regimof
I have no clue what hoses they are.
Heater core job it is. Problem is I don't know that I'm terribly qualified for a job that big. Yikes
Regimof is offline   Reply With Quote
Old 10-18-2016   #17
Go boldly
