![]() Join Date: Feb 2010
Are the dowel pins on the ZR-1 block the same as a small bock chevy?
Small bet with with another corvette owner. I said yes they are he says no. Winner gets free lunch! John |
![]() Join Date: Oct 2004
I'm inclined to say yes and if you check one and find it to be 5/8 X 1 3/16 that would confirm it. If you're needing most very good hardware/machine supply houses should be able to help you. GM# 12338119 is likely NLA.
I stumbled upon a bit of conflicting information that I couldn't ID. There's a GM# 10067627 that appears in some older SPO applications but description and quantities used is contradictory. I can't find any dimensions of the part either. I thought maybe it was the GM# for the case locating dowels M6X25 but I certainly can't document it. Last edited by WVZR-1; 07-18-2016 at 10:58 AM. |
I have some OEM dowel pins. Having converted a 4+3 to a ZF-6 on my 84 Xfire, the dowel pins were the same altho the bellhousings differ somewhat in length between LT-5 and generic SBC due to input shaft.
![]() Join Date: Dec 2003
#5 | |
Thanks for the information. I just ordered a set (2) from Jerry's.
#7 | |
I had the wrong PN associated with the Block/Clutch Housing Alignment Pins, which has now been corrected to 10067627. Was, right part with wrong PN! Now, right part with right PN :-)
#8 | |
The 5/8(.625) is a reference diameter GM used even after engine conversion hardware to Metric spec. for clutch housing. All LS spec through '14 are. ***It might be interesting to confirm bore dimension of a block. Jerry? Anyone? Last edited by WVZR-1; 07-19-2016 at 06:26 AM. |
PN 10067627, Block/Clutch Housing Alignment Dowel: 0.6198" dia (15.743mm)
#10 |
