Old 07-16-2016   #1
jon_d4
Default Help! 1st Time Removing Plenum....now rough idle
94 ZR-1
I just removed the plenum to fix an oil leak from the crankcase vent and tubes. Got everything back together, and I'm getting a really rough idle and the car won't rev above 3k. It runs fairly smooth up to 3k, then it just pulses and shakes violently refusing to go any further.
I've already pulled the plenum back off once to check all of my vacuum lines and that I have a good connection on all of the plug wires. It's still possible that I've missed something, but I've rechecked as much as I can.
It's also throwing a code, but since it's a 94, I can't get the ECM codes by just jumping wires on the connector for the ALDL.
Advance? What is the most likely offender? Thanks for the help.
jon_d4 is offline   Reply With Quote
Old 07-16-2016   #2
mike100
Default Re: Help! 1st Time Removing Plenum....now rough idle
you can get the codes to display on the orange speedo lcd on the 90-up cars.
but my guess is that maybe a pin on the ignition module got bent trying to get that long connector on the back plugged in. Take off the map sensor bracket and get your 1/4" socket out...
Old 07-17-2016   #3
jon_d4
Thanks for the responses, guys.
MAP vacuum
I checked the vacuum line from the MAP sensor to the plenum. I removed it, reinstalled, made sure it was tight, then ran the car again. No change. Thoughts?
Old 07-17-2016   #4
jon_d4
So, after checking the MAP sensor vacuum, I pulled the plenum a third time to check the connector for the ignition module. I was having trouble getting to it without lifting the plenum up. All the pins on the connector look good. On the bright side, I'm getting a lot faster at removing/reinstalling the plenum....
Old 07-17-2016   #5
Billy Mild
Did you remove the Throttle body at all?
Could you possibly get a video of the car running? Even a cell phone video would help for this.
Old 07-17-2016   #6
cvette98pacecar
Pull the water seal on the DIS plug back, I guarantee you one of the pins is pushing out when you install the plug, with the water seal pulled back you will be able to tell which pin it is within seconds. I don't remember if these pins are 100 series or not, They are easy to change if needed.
Don't cut or shorten the wire, Take your time and open the crimp connection. Sorry to tell you but the tool is special and a good GM terminal tool is going to cost you about $100.00.
Old 07-24-2016   #7
jon_d4
So, just wanted to wrap up this post and fill you guys in on the results. Sorry for the delay. I was traveling for work this last week and wasn't able to work on the car until yesterday.
Car is now running great! I think my issue was actually the vacuum lines going to the MAP sensor....I pulled the plenum and checked the connector going to the ignition module like was suggested; everything looked good. Well, when I got it all back together the car wouldn't run at all... I was out of time to work on it, so that's where it sat until yesterday.
I pulled the plenum again to recheck everything and discovered that I had two of the ignition coils swapped on the drivers side of the car. When I pulled the plenum the last time to check the connector for the ignition module, I also pulled the ignition coils and the plate above the starter out to retrieve a dropped bolt and must have got them mixed up then.
I got it all back together and double checked my vacuum line going to the map sensor....fired right up and didn't throw a code! Thanks for your help, guys!
Old 07-24-2016   #8
jon_d4
MAP vacuum
Nailed it. Thanks!
Old 07-24-2016   #9
jon_d4
Thanks for the help. My connector was okay. I checked that all the pins that had wires running to them were still present in the connector. I also checked the ignition module to make sure I didn't damage anything on that side. This is good advice, as I'll now pay extra attention to this connector each time I remove/install it.
Old 09-09-2016   #10
2ljd
jon_d4,
I just got through doing my first plenum pull and encountered the same problem you described...it starts and runs, but really rough, almost like a few cylinders are missing.
I noticed early on you mentioned checking the MAP vacuum line initially and it still wouldn't start. But, on your last plenum pull you thought it was the MAP vacuum line. Was there something you noticed the last time around that led you to believe it was the MAP vacuum line? Too loose? Did you have to fix the seals as some have done with crazy glue?
I inspected my MAP vacuum line twice and it seemed alright...although I can't say for sure that it somehow isn't leaking despite my visual inspection.
Just trying to get a feel for what your problem was before I pull the plenum again. By the way, I changed my plugs, wires, coils and injectors, so I have a lot of investigating to do...
It ran fine (other than a slight miss I figured had to do with the injectors; original with only 7K miles on the car) before I pulled the plenum.
2ljd is offline   Reply With Quote
