#11 |
Thank-you for everything BTW!!!!
Where is the relay located??? I will check connections on the pump assy. In the tank |
#12 | |
![]() ![]() Join Date: Nov 2007
Next, I would "divide and eliminate": see what you have at the fuel pump connector. Note: Before going further, do NOT expose fuel vapors to the potential of electrical sparks - especially when making voltage measurements with an open fuel tank!! (Course you know that, but you might not be the only one on the internet reading this!) If it is good there, then check resistance of both pumps, measured between the input power and the ground. Also, inspect both halves of the connector.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 06-28-2016 at 01:41 PM. |
#13 |
Not worried about fuel vapor and sparks....I live in front of a fire station!!!
#14 |
These are my two readings...
16.7 ohms 3.1 ohms Hmmmmmm...... |
#15 |
Ignore those readings they are just an anomaly...
The connectors are corroded due to water that was in the tank. |
#16 |
Good job. Now, when the connector is cleaned up and sealed, is the resistance through the pumps more or less the same? If so, button it up. But, now go back to step (one) and measure current w/ the key off. It should be between 8-10A at the pump prime connector, yes?
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
#17 |
Pumps put out 6.17a under load with gas and 2.70a pumping dry.
they both read about the same...they seem like replacement delco units from 2014.....All contacts were cleaned thoughly ....crud and water at the bottom of the tank....first offer of 7k CDN takes this puppy home( sans water in the tank).. Got my order in from Jerry's today... |
#18 |
![]() Join Date: Dec 2007
Selling the car for 7k?
#19 |
In a sarcastic and somewhat sadistic way yes!!!!....I just don't have the resources or time for this project....
#20 |
Post some pictures of the car..
