#41 |
![]() Join Date: Jul 2010
5th gear wound at 8000rpm would be 201mph. Yeehaww smoking for sure.
I've not heard of the F-body guys having these 6th gear issues with their T-56's. Hmm, this sounds scary. Does Mr Boudreau's rebuilds focus on this problem area? |
#42 |
![]() Join Date: Dec 2014
Dempsey at Evolution Motor Sports, has me back on the road with the same 610Nm type transmission swap completed, Spicer joints, Fluted pilot bearing, Amsoil Syncro-mesh fluid
...and special thanks to Bill Boudreau Zfdoc, Mark Haibeck, and Rockland Gear ZF for their advice & instalation notes. |
#43 | |
I wanted to wait for George to post ![]() I the drive-system is in and ops checked for about 15 miles, still a few more odds and ends to tie up, but I REALLY ENJOY diving this car!!. As George said, New Spicer's, An Early 90' black tag 610 Trans, New FLUTED Pilot bearing(would you like to see the old one?????? ![]() **Will post pics asap** George did well with the Corsa, combined with the cams and porting this car is a BEAST. I will put some HI-RPM testing in tomorrow, then when George gets down here we will set him up with another dyno run. Dempsey Last edited by oricale; 06-13-2016 at 11:35 PM. |
#44 |
Test drove Georg's 90' about 130 miles with NO issues!,.. feels like a cammed-Corsa piped ZR1 should feel(tests of: High RPM driving, 90-100MPH in both 5th and 6th,low and high load at gears, smoothness of shift and positive pattern, we then temped, checked C beam torque and trans oil checks after run). The rear 4/10's do whine at 5/6th gears at about 50 and up(cut pattern?. But over all it is a ported, polished, cammed and piped car. You get what you ask for
![]() ![]() Whats that you say??...The pilot bearing?....are you sure?..(please remove small children from the room ![]() ![]() Interior is worked just a bit, seats, A/C cleaning and removal of dash-rug!(dash cover--history!) ![]() ![]() Last edited by oricale; 06-15-2016 at 10:27 AM. |
