#21 |
![]() Join Date: Dec 2014
4.10 mod wasn't done recently. The transmission and shifter felt real good. Engine was strong, cams & Corsa sound mean. Any recent work (a ton of it) was unrelated to the transmission, to my knowledge.
Dempsey will have more info when he opens it up. So, I should look for a replacement transmission with Bill's spline modification? Or, send him my core for exchange or rebuild? |
#22 |
![]() Join Date: Dec 2003
My transmission (94) seized & locked the complete driveline. Rollback wrecker spotted it close to my lift where I could put a jack under the 3rd member, winched it up to the lift & oiled the rear tires to slide the rest of the way on. Locked up solid just cruising around town.
Sent it to Bill Boudreau for the full ZF Doc treatment.
#23 |
![]() ![]() Join Date: Aug 2005
Wow, 2006! Deja Vu all over again.
I agree with Paul & Jerry. My BB trans has performed BEAUTIFULLY ever since. Smooth, positive shifting, no noise. And like other times I have broken, I use it as an excuse to upgrade: BB short shifter is the BOMB! (my kids tell me that's a good thing.) From what I remember: broke down in the desert. Buddy took me into town and I rented a U-Haul and trailer. Backed car up onto trailer and took her home. I removed the half shafts and pushed my car into garage. Dropped trans (MUCH heavier than I expected). REALLY fun lining up trans/splines/shaft lying on your back under car up on jack stands. I now have a Kwiklift but 2 - 4 post lift with trans jack is best. PS: Or have somebody like Dempsey or Bill nearby Last edited by tf95ZR1; 06-01-2016 at 10:28 PM. Reason: Wanted 2 |
#24 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 06-01-2016 at 10:36 PM. |
#25 |
Jumped from 2006 to 2016. So.....what are the odds and what are contributing factors?
Bill says If there is an oil level and/or oil condition issue, this is the area in the transmission which is prone to seizure. What are the Oil Level and Oil Condition ISSUES? Oil Level is obvious but am I to assume some oil levels are significantly below the top fill port? And.....am I to assume if you have fresh TWS 10W-60 Castrol you are in good condition and have significantly reduced the chance of this Transmission Lock Up to happen? I have Bill's C4 Beam Plates on ALL ZR-1s ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2016 at 12:45 AM. |
#26 |
Hey all!, we are in the process of going through George's car, the transmission is out, the trans oil has been checked, levels were correct and albeit full of bits of transmission, it was clean..pilot bearing is shredded and partially laying in the snout (location of engagement of trans to crank). We are pulling the clutch pack for inspection as well as replacing u-joints on the drive shaft, the event was pretty violent.---more to follow----
As far as modding for 4/10 gears.....I am aware of at least 5 guys on the site that utilize 4/10 gears with no mods and drive 1000's of miles with no issues. However, if there is a mod that will guarantee a life free from a trans eating itself due to this issue,.. and its proven. I'm all about it ![]() First drive breakdown blues are a downer ![]() ![]() |
#27 |
Beam plates on both cars already...huge difference in driveline deflection (rear-end kickout), and rising shifter when a rear top plate was lost recently on #1587. Bill made one up for me.
As per your suggestion, I left a message for Bill today. I'm of the opinion to fix it right, fix it once...although I would like to hear everyone's experience. I'm told there are a handful 4.10 geared cars, driven long distances that haven't had this transmission failure occur. Once the car abruptly decelerated itself from highway speed cruising in 6th gear, all I had for movement was a crunchy sounding reverse gear. Any forward gears would stall the engine. Then the trans got stuck in reverse, regardless of any shifter position. The clutch has to be depressed to push the car around, so I'm not completely locked up. |
#28 | |
OK......What caused this or are we driving ZR-1s that can for no particular reason all of a sudden lock up at any time (that would be hell in traffic for sure). Or are we driving AT RISK ZR-1s that in their history have run for a long while low on oil or oil not changed at any particular interval. What would prevent this and how often does this occur? what are the statistics? Or....can we put this issue in the same category as Timing Chain Catastrophic failures (I know of only two) which are extremely rare and equally unpredictable.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2016 at 01:25 AM. |
#29 |
Bill Boudreau would be the best one to obtain failure statistics and cause. I recall several failures of transmission seizures over the last 14 years, but it would be a stretch to say it's anything more than than an uncommon occurrence.
Circumstances of my particular failure; Model: 1994 Mileage: appx 60,000 miles Lube: original fill replaced with Redline. Original oil was full & clean. Failure occured within 2,000 miles of Redline. I make no claim that Redline was the cause. Impending failure warning: Slow roll to stop, clutch depressed, no brake, could feel slight abnormal decel & stop with brake. Knew something was wrong & started home. made it about 4 miles. Conditions: Cruising in town, speed 0~45mph. Failure: left stop sign, rolling resistance significant, clutch no effect. Seized completely.
#30 |
I am aware of 1 case of timing chain failure that was directly attributed to cam cover chain guide that came loose after powdercoating. Guide (facing removed) was left in place during powdercoating. Loctite may have been affected by heat.
