Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 05-03-2016   #11
92whiteZ
Default Re: GM part search
thx WVZR. the link shows no products available. the couple times I called baer I got a handful of different responses. I got lucky finding the 2nd set, pure happenstance.
92whiteZ is offline   Reply With Quote
Old 05-03-2016   #12
WVZR-1
Originally Posted by 92whiteZ View Post
thx paul. I thought these might not be gm parts. baer said they "machined" them in house but I see no evidence of machine work like I see on the spindles to accommodate the caliper bracket.
combing through the timkin catalog to see what hubs use SET3 bearings.
there should be 2 bearing sets used inner/outer.
Here's an SKF catalog that if you just use the "part information tab" and then the part # it will display the buyers guide applications for all. Click on the BR3 to the left to open the "part detail section".
Use BR3 for the "set 3". 265 applications for "set 3/BR3"
http://www.skfpartsinfo.com/
