Old 04-10-2016   #1
Jetjock
Jetjock's Avatar
Default Replacing clutch safety switch
Anybody here actually replaced the clutch safety switch instead of bypassing it?
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 04-10-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Replacing clutch safety switch
Why would you want to do that?
Old 04-10-2016   #3
Mystic ZR-1
Mystic ZR-1's Avatar
Jumpering out the switch is MUCH easier!
Old 04-11-2016   #4
Jetjock
Jetjock's Avatar
Because I want to and I need it for NCRS. It's a safety feature. I did that to my 92 ZR-1 and I've tried to start the engine several times with it in gear and because I hop back and forth between automatic Vettes and manuals.
Roy L. Carman
NCM Lifetime #1468
Old 04-11-2016   #5
I did that on my 84. You really need to take the seat out. It is a HUGE, HUGE
PITA.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-11-2016   #6
Mystic ZR-1
Roy
Checklist every time!
Old 04-12-2016   #7
Jetjock
Jetjock's Avatar
Doug, you keep bringing that up. There are no checklists on cars! I've decided to jumper the contacts and when the time comes, just pull the jumper wires out. I won't be driving the car to the NCRS meet and so it will be cold when they go through the items. Should work. It won't work when it gets hot and the trick is to keep it cool and not run it long.
Roy L. Carman
NCM Lifetime #1468
Old 04-12-2016   #8
I do not know why you are replacing clutch safety except you want to
It sounds like typical starter solenoid to me needs refreshing if in fact it is a no start and especially if the no start happens on a hot engine starter.
Old 04-13-2016   #9
THAT WAS MY THOUGHT TOO.
Jet: No start when hot is NOT a safety switch phenomenon. However, that is characteristic of the starter solenoid windings. So, if it is the solenoid is failing, bypassing the clutch safety switch will not be a "work-around" solution to that problem; but a new solenoid will.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-13-2016   #10
Jetjock
Jetjock's Avatar
I understand that but the starter is new. In my experience, limited as it may be, it points to the safety switch. However, I will try it out this weekend and see what happens. This has happened before on my 92 Z. I did replace the starter and the solenoid and it still did it. When I bypassed the safety switch, never did it again. Also, I'm looking at NCRS and it has to work at that point. However, by trailering it down, I avoid that. Besides, I have a set of GSC's and I don't want to drive on them 1000 miles.
It only happened one time but it was a time killer waiting for it to cool down.
Roy L. Carman
NCM Lifetime #1468
