Old 02-09-2016   #21
Default Re: Single Mass Flywheels
Thanks for your post Jitse!
Old 02-09-2016   #22
So for a stock HP set-up If I needed to swap the dual mass I would do the 22# flywheel with sprung hub disc. That way I have some Dampening
Yes
Flywheel:
http://www.jerrysgaskets.com/flywhee...let-90-95-0b1/
Clutch Disc:http://www.jerrysgaskets.com/clutch-...hub-89-95-000/
Pressure Plate
: Stock/OEM pull-release
Old 02-09-2016   #23
edram454
edram454's Avatar
That's what I have been using w my Fidanza. It's a Camaro LT-1 sprung hub disc.
I also have a camaro sprung hub clutch with my fidanza and hear no rattle whatsoever with the benefits of a super light flywheel is well worth the money.
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 02-09-2016   #24
I know.. just confirming the set-up with the 22#
