#11 | |
Thank you! |
#12 |
#13 |
![]() Join Date: Jul 2007
Jerry do you suggest a sprung hub disc with your 22# flywheel?
#14 |
![]() Join Date: Dec 2003
It depends on the power level and what type of use the car will see, rather than the flywheel. A sprung hub will absorb engagement shock better than a solid hub thus provide more drivetrain protection than a solid hub WHERE HIGH LOADS OCCUR, i.e. with significantly higher power output than stock. If the car will see frequent strip use with drag radials or slicks, I would recommend the 900/300 series disc with sprung hub. We do not stock this disc, but it is readily available from RAM.
For street/strip use (street tires), I would recommend the 300 series disc, sprung hub or solid hub, with Marcel carrier. We stock the RAM 11" 300 series solid hub disc, with a Marcel carrier for use with the stock pressure plate. The 300 series disc uses organic facing for a smoother engagement. Intended use and driving styles make clutch choice subjective. With so many combinations available, disc types, facing material, sprung or solid hub, flat vs Marcel carrier, it can be difficult to decide. What one driver thinks of as spirited can be seen as hard driving by another. So, there is no pat answer for all drivers and applications. It may be worthwhile to choose a higher load capacity clutch than actually needed to better insure the outcome. Just remember that the closer you get to building a race car, the less comfortable driving on the street becomes. (Ask me how I know that. ![]() A good read, scroll down to the clutch discs. https://www.ramclutches.com/images/catalogs/cb2010.pdf
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-09-2016 at 12:12 AM. |
#15 | |
![]() Join Date: May 2010
I'm glad you posted about these flywheel options. What are the differences between the 18# and 22# other than 4# difference? I was about to send in a stock dual mass to Jim J for resurfacing, but really hate how heavy stock is. I definitely never want to consider a Fidanza again as I don't like the sound of all that rattling. Do you have any customers with the 18# or 22# that we can consult with about rattle? Thanks, Craig
#16 |
![]() Join Date: Nov 2007
To help mitigate the rattle when using a 13# (Fidanza), the following steps together resulted in almost completely eliminating (you be the judge) while retaining the stock PP:
Camaro, sprung hub disc (Summit) part #381039 Increasing the idle speed to 850-900 rpm Accel injectors #150821 Also, unrelated to the noise issue, an ARP bolt kit and tap was purchased. The purpose was to facilitated drilling and tapping the holes in the FW to approx 1+" to give the bolts a little more purchase due the aluminum vs. cast iron to secure the PP to the FW. I also used new Grade 8 bolts and red Lock-Tite to secure the FW to the crank. All GOOD for 6 seasons now w/o issues. See what you think: https://www.youtube.com/watch?v=y1YFa8ruh8A Note: At the time this video was shot, it was 21ºF and the transmission was cold, and filled with synthetic Castrol TWS which is no longer available. It now has Redline Shock=Proof (HD) synthetic, which seems to work about the same as the TWS, far as I can tell. |
#17 | |
Re: Motive behind the 18# & 22# weights; 18#: (1) Same physical dimensions as dual mass unit & (2) as light as practical, given the dimensional requirement. 22#: (1) Weight inspired by the single-mass, iron flywheels produced by Doug Rippie many moons ago. Many years ago, Doug acquired Camaro single mass flywheel castings & machined the mounting flange for the 8 bolt LT5 pattern. They were very popular, but now very unusual to find one. (2) Having another choice to help bridge the gap between 13# & 37.5# to allow better flywheel mass tuning for driver preference. Other than 4 lbs, there is no difference. Re: Customer reference for noise mitigation with 18 & 22# flywheels. We only have one 18# flywheel sold to date. That sale was to a European customer. Unfortunately, I can no longer access the sales record details to try & contact him to ask about transmission noise. I do remember that he wrote back to say the install went perfectly and he liked it very much. Transmission rattle was never mentioned.
#18 |
So for a stock HP set-up If I needed to swap the dual mass I would do the 22# flywheel with sprung hub disc. That way I have some Dampening
#19 |
#20 |
![]() Join Date: Aug 2013
The # 18 single mass flywheel ( sold too the europe customer).
Is running smooth, just a little bit noise, but not something which is irritating. The idle is moved up to aprox. 850 rpm. The guy and I am happy with it, can recommend it. My own Z has the fidanza, but if I ever need a new one its gonna be the #18 from Jerry. Last edited by Jitse; 02-09-2016 at 02:35 PM. Reason: Spelling check |
