![]() Join Date: Dec 2003
Just arrived today!
BTW, A fellow ZR-1er loaned me a good quality, original connector at BG this year. I need to send his back with a nice thank you for loaning it to me. If you are that guy, excuse me for forgetting your name & please contact me. http://www.jerrysgaskets.com/connect...-new-1990-000/ ![]()
Jerry Downey [I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I] [URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL] 1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-13-2016 at 12:26 AM. |
![]() Join Date: Apr 2004
Nice... makes me with I had a 90
![]() Join Date: Nov 2011
Nice, I heard Jerry was working on these.
Yea, thanks. Please keep the unobtainable parts coming.
![]() Join Date: Jul 2005
Very nice. Thanks for the support Jerry.
Jerry.....I might add that the three PCV connectors (actually four as there are two Injector Housing Connectors) are also a great improvement.
These three connectors are compatible with 1990 - 1995 ZR-1s ![]() Jerry's Dual PCV Valve Connector Jerry's Dual PCV Valve Connector Hose Jerry's Dual PCV Valve Connector Grommet I installed Jerry's New Dual PCV Connectors on ALL engines getting rid of all the Clap Trap Nylon Ties and Hose Clamps to keep the Old (hardened Rubber) Dual PCV connectors from slipping off the PCV valves/lines or leaking Highly Recommended ![]() Right up near Top Of List with Blocking TB Coolant at each Injector Housing. ![]() ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-13-2016 at 12:39 AM. |
#7 | |
