Old 12-09-2015   #1
msorenso
msorenso's Avatar
Default LT-5 Head Air Flow #
Hi All,
Does anyone have a link or know what CFM the stock LT-5 heads flow at? Thanks you
msorenso is offline   Reply With Quote
Old 12-09-2015   #2
Pete
Pete's Avatar
Default Re: LT-5 Head Air Flow #
I have them somewhere if i find them i will post them for you.
May i ask why you want them?
They mean nothing unless you test on same flow bench.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-10-2015   #3
Copy from Corvette Forun
"Here's something that was posted on the ZR-1 Net by Greg Van Deventer:
Here's some intake numbers from a stock 1990 cylinder head tested @ 28" H2O
on a stock 3.900" liner with secondary port throttle assembly and clay
radius...
Lift CFM
.1 92.78
.2 167.97
.3 222.01
.4 246.84
.45 256.86
.5 263.44"
Old 12-10-2015   #4
msorenso
msorenso's Avatar
Thank you for the posting. No problem, Just curious how they flow in comparison to other heads LT-1, L-31, Lt-4, LS1 etc.
Old 12-11-2015   #5
rkreigh
new LS stuff is way better but it's not all about "raw cfm" flow quality, tumble, mix, detonation reistance and of course flow velocity make the LT5 work pretty good depite the rather low bench numbers
a good set of ported heads will sneak up on 340 cfm and support well over 700 ponies
above that you are a bit flow bound.
FYI the out of the box new LS7 heads flow 370+ which stomps the living crap out of our heads but of course a 4 valve head has many other advantages such as lighter valves, less valve shrouding, low tension springs
and pete is right, flow benches like dynos don't tell the whole story
Old 12-11-2015   #6
SAM/CH ZR-1
I wouldn't pay the final attention to max. cfm numbers.
There are other important things to consider. A 700 HP LT5 perform different and better than a 370 cfm flowing LS7.
We brought a C6 Z06 on the same car weight like a C4 ZR-1 and did some acceleration tests. The LS7 pulled in spite of its 427 cui pretty modest.
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 12-11-2015   #7
Of course you are right Sam. The motor spends most of its time in the mid lift flow area. Max flow is visited very briefly.
