12-05-2015 | #1 |
Idle to high around 2000rpms
So I need some advice from the experts. I have a good friend here in Ga. who has a 91 P&P headers exhaust and tune If i had to guess 500 flywheel HP.
He can not get the idle down below 2000, This just started after the car sat for an extended time. I went over and helped check out the normal things such as vacuum or vacuum leaks none found. I hooked up my scanner and what I did find was a code 62, and the 02's never cross counted the stayed around 750-800 both right and left just a flat line?? He does run a % of race gas in it could that have burned up the 02's? Will the 02's create this high idle issue? Thanks Guys any help will be great.
12-05-2015 | #2 |
Re: Idle to high around 2000rpms
Steve, are you sure there isn't a vacuum leak under he plenum?
When my (stock) ZR-1 had a 2,000 rpm idle, Marc H said (almost immediately) it was a vacuum leak, and he was right. I'm not sure if fouled O2 sensors might cause high idle. Good luck. |
12-06-2015 | #3 |
I agree vacume leak. Last time I left a vacume hose off under the plenum
it idled at 2000. Pulled plenum again, reattached loose tube, prob solved. |
12-06-2015 | #4 | |
12-06-2015 | #5 | |
We got to talking about car and stuff I had not seen Mark in many years so we had a lot to catch up on. I'll make a trip back when I get more information may be a few weeks as its about a 100 drive one way. Was a great drive in the 93 for me!!! but the cam cover washer I replaced was still seeping just a bit. I hope he does not mind but this is his beast...One great looking ZR-1
12-06-2015 | #6 |
I agree. Very nice.
12-07-2015 | #7 |
Any other ideas or comments.
12-07-2015 | #8 |
You have verified the MAP hose? Its sounds like an under hose plenium leak. The MAP would/should show an open fault as well
12-07-2015 | #9 |
Option other than bad O2: Verify whether the 2000 rpm idle is vacuum leak or throttle related. Put a heavy book or piece of plywood over the air horn while running. Engine dies, it's throttle or IAC related, keeps running, it's vacuum.
12-07-2015 | #10 | |
Yep thats right Jerry anything that can block the intake I used a piece of cardboard it does the trick as well
