Old 09-08-2007   #11
Default Re: Time to replace injectors
Originally Posted by Aurora40
As in stock GM '90 injectors? FWIW, if you decide to still go GM, the '93-95 injectors would be a better idea.
Wow guys Jeffvette back me up here do not put Stock GM injectors back in they cant handle the additives in the fuel these days. GO with RCs and do this job once or give the Accels a try. Wow bad idea
Old 09-08-2007   #12
Aurora40
Aurora40's Avatar
The '93+ injectors are rated to handle up to 10% ethanol. This is the same as any other injector on the market.
Bob Saveland
Former owner of #2517
Old 09-08-2007   #13
ffvetteman
I didnt need the o-rings on my 92.
I used the Accel injectors.
ffvetteman is offline   Reply With Quote
Old 09-09-2007   #14
I was in a bind (few hundred miles away from home in bg) with several bad injectors so I went with what I have....next time is RC
