Old 09-14-2015   #11
G-Sting
G-Sting's Avatar
Default Re: Wheel bearings
Originally Posted by Fully Vetted View Post
Do I replace the entire hub?
Is this something that can be done in the garage with a formidable amount of tools and some decent mechanical skills or is it a trip to the Vette Clinic?
David,
Here is a helpful video I used recently.
Also, I posted a few pics on this thread. I did not replace my rear wheel bearings, as they were in great shape. Just removed, cleaned up the splines, lubed, and put back together.
Hope it helps. Wasn't bad with the proper tools.
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
Old 09-16-2015   #12
Fully Vetted
Fully Vetted's Avatar
Anybody have any experience with these?
http://www.corvettemods.com/product....FdcSgQodkBIFJw
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 09-21-2015   #13
Fully Vetted
Anybody have a part number for the Teflon washer?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 09-21-2015   #14
Billy Mild
What is the part number for the concave washer. Mine was pretty well corroded.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 09-21-2015   #15
Jagdpanzer
Jagdpanzer's Avatar
GM P/N 14076924
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-22-2015   #16
Fully Vetted
Thanks, Phil.
Got all my parts ordered. I decided to spend the extra money and get the USA made Timkens. I read several threads on different sites of installing the Chinese sourced Timkens only to find out they were bad right out of the box. I only want to do this once. Ordered the Teflon washer from GM Parts Direct ($11 for 2) and my Spicer half shaft u-joints from DennysDriveshaft.com.
I'm sure it will all make sense once I get started but I'm assuming I'll take out the half shafts first since that will give me easier access to the T-55's for the hub assembly? Any tips?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 09-28-2015   #17
Fully Vetted
So, it turns out Ecklers was the only place I could find USA made Timken's. I ordered 2 but they only have one and not scheduled to get any more in until the end of the year(?). Does anyone know of a place that carries them?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 09-28-2015   #18
Agpilot1
Hi David, you might check with these guys. The description says Timken USA.
https://www.vansteel.com/index.cfm?f...t&subgroup=202
Hope this helps your search.
Shea
'90 #2815----SOLD
Agpilot1 is offline   Reply With Quote
Old 09-28-2015   #19
Jagdpanzer
Jagdpanzer's Avatar
FWIW RockAuto lists TIMKEN 513020 rear bearing hubs for under $100
http://www.rockauto.com/catalog/x,ca...,parttype,1636
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-29-2015   #20
Fully Vetted
Thanks, a ton. I'm working with a couple of local parts houses (not O'Reilly's or AZ...real parts houses) that say they can get them. They should be in tomorrow. We'll see if they're USA or not. I'm thinking they are because of the price point.
Thanks, as well. Pretty certain these are Chinese. I haven't found any place that had USA made for under $200. Chinese sourced are in the $100 to $140 range.
Thanks for your help, guys.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
