Old 08-13-2015   #1
BlackZR1
BlackZR1's Avatar
Default ECM Scanner Recommendations
I've searched the forum for alternatives to the Tech 1 but can't find anything. What do you guys use to measure engine parameters and read codes? When I had my '94 Camaro I had some freeware on my laptop and an ALDL/serial port interface that allowed me to view and log sensor data.
What are my options for my '90 ZR-1?
Thanks,
Roger
BlackZR1 is offline   Reply With Quote
Old 08-13-2015   #2
Default Re: ECM Scanner Recommendations
Bluetooth OBD1 device:
http://www.1320electronics.com/12pinALDL.html
Android App:
ALDLDroid
Then your Android phone or tablet
Old 08-14-2015   #3
BlackZR1
BlackZR1's Avatar
Android App:
ALDLDroid
Thanks Jeff. the first thing I want to do is document my baseline readings so that when/if I have problems I have a basis for comparison.
Roger
Old 08-14-2015   #4
Roger
Roger,
I would encourage you to get an scantool and familiarize yourself w it, but there really isn't any need to document your readings. They're either normal or you'll end up w a MALF code.
Old 08-15-2015   #5
Billy Mild
Android App:
ALDLDroid
Would this replace a MT2500 or Tech 1?
Old 08-15-2015   #6
What options do those have? What can they do?
Old 08-18-2015   #7
Billy Mild
Tech 1 is the factory scanner from GM. It does everything
MT2500 does most functions except for TPMS and Suspension troubleshooting.
Old 08-18-2015   #8
I doubt it will replace.. It only handles ECM..
Old 08-18-2015   #9
Don't think either one data logs.
Old 08-18-2015   #10
right, while the Tech 1 has more troubleshooting capability, i think for most engine related issues, the stuff i suggested will be fine..
