07-30-2015 | #51 |
Re: LT5 miss at all speeds
With the schematic/diagram I can trace the circuit inside the ECM to see what controls the injector and if I find that the ECM is causing my problem I can hopefully determine if the internal circuit is replaceable or repairable. W/O the schematic/diagram I haven't a clue.
07-30-2015 | #52 | |
07-31-2015 | #53 | |
Re-pin the connector with the pins I sent you. Try not to overthink this. It's not totally inconceivable that you might have a bad ECM, but you won't know for sure until you fix the pins first. I made the same mistake. Took me over 3 years, more cash than I'll ever tell wifey about, untold stress and aggravation to finally nail it down. And truth be told, I'd likely never have found it if it wasn't for this Forum. The Brotherhood of the Beast is alive and well. 'Crabs
08-03-2015 | #54 |
Any luck? I finished my injector/plenum job. Everything came out OK. I just had to decide when to quit cleaning or fixing things. I wanted to be able to enjoy it this summer and remember that winter is coming.
Ken "IMZZ" 1991 ZR-1 Corvette 1990 MX-5 Miata |
08-18-2015 | #55 |
my father changed the back 2 plugs the other day and it runs great now. Not a damn problem.....except my bose radio lol Did you ever find out why your lt5 is missing? I am curious
08-18-2015 | #56 |
Hey Paul it turns out it was just my plugs, but what did you do to fix your valves. Were you able to buy a single valve? did you have to buy a whole head? and where could you even purchase valves or a head?
08-18-2015 | #57 | |
https://www.google.com/shopping/prod...acF8WzeuH_logC |
08-18-2015 | #58 | |
Still is pointing to the ECM with the big difference in resistance between #6 and the other 7 pins into the ECM. Not yet willing to shell out the $300 or more to experiment. |
08-18-2015 | #59 | |
08-18-2015 | #60 | |
www.jerrysgaskets.com
