Old 04-25-2015   #1
tpepmeie
Talking 427 LT5 Build 2 underway
Here we go, guys. Thought I would make a new thread to document build 2. The target is 800 bhp, @ 7400 rpm. Some upgrades from the previous version (700 bhp/6900):
  • New larger inlet valves (41.5mm v. 39.5mm)
  • Higher compression ratio
  • Billet aluminum mono blade throttle body
  • New cams...maybe
Here are two links to other discussions about Build II.
http://www.zr1.net/forum/showthread.php?t=23894
http://www.zr1.net/forum/showthread.php?t=23537
I was never really happy with the ring seal on the first build, both from a blow-by and oil control perspective. So, we're now using new pistons, a different bore finish, and new rings. These pistons (430g) are a bit heavier than the featherweight CP forgings I used in build 1, so the crankshaft will need rebalanced. The intention is to get better stability of the piston in the bore.
Ross Custom billet pistons. 14:1 / Flat Top / .140" deep valve pockets made from a mold of my combustion chamber. These valve pockets will accommodate more than .550" valve lift if I decide to go there...
.043/.043/3mm Total Seal rings
Old 04-25-2015   #2
Default Re: 427 LT5 Build 2 underway
Groundbreaking stuff Todd. You're one of the people we should celebrate for advancing the ball!
Old 04-25-2015   #3
Gas ported pistons nice option.
Old 04-25-2015   #4
Blue Flame Restorations
What bore finish are you planning to use?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-25-2015   #5
I've seen the groove between the compression rings on Mahle LT5 pistons before. Can you elaborate on yours?
Old 04-25-2015   #6
tpepmeie
Whatever Total Seal recommends . Seriously, though, I think the finish hone is 280-320, with a specific cross hatch angle. Keith Jones at Total Seal is the guy.
Old 04-25-2015   #7
tpepmeie
Jerry,
most all of the high end pistons have this. I believe the theory is to provide more volume for the gas pressure that escapes past the top ring. The groove helps relieve that instead of compromising the ring seal in the land. At least that's the way I understand it.
Old 04-27-2015   #8
tpepmeie
I added a couple of links to the original post, just to keep it all together.
Some other upgrades for Build II:
  • Custom main bearing studs
  • ARP head studs
  • Cometic MLS head gasket
  • Custom heavy duty secondary cam chains ()
  • improved crankcase ventilation
  • upsized fuel delivery system, incl. new rails & adj regulator
  • alpha-n fuel calibration, fully mapped on engine dyno
  • RAM dual disc clutch
That's all I can think of right now. This should be fun.
Old 05-03-2015   #9
USAFPILOT
USAFPILOT's Avatar
Is this a second engine or a rebuild of the 1st 427?
Old 05-04-2015   #10
bradley
could you share what your doing to improve the crankcase vent system ??????
bradley is offline   Reply With Quote
