Old 08-11-2007   #1
Default Plenum Pull Q's
Hi guys,
I should know this but I'm old & senile & I forgot!
If you have to pull the plenum you should wait for the motor to be stone cold, right????
I know it's a stupid Q. I rent a garage to keep my Z and I have to drive to it to do any work on the car. It's not that far but by the time I get there I'm about 1/2 way on the temp gauge. So I'm thinking that I should not work on her till the coolant is cold to the touch, right???
Thanks,
Old 08-11-2007   #2
cuisinartvette
Default Re: Plenum Pull Q's
I feel your pain, I have to drive across town to a garage I keep mine at too. What a PITA if you forget tools....Guess thats why mine has sat for so long.
Id drain some coolant from the pitcock on the radiator before pulling it off. Plenum will be warm to the touch for a bit.
Old 08-11-2007   #3
Aurora40
Aurora40's Avatar
I'd think it would be more for your sake than the cars, though. I imagine you could pull it off warm and it would be fine, if your hands can stand it.
Why do you have to go under there again?
Old 08-11-2007   #4
Thanks Ron & Bob! I seemed to think I remembered an old time wrench telling me never to dis-assemble a hot motor????
Ron, I feel your pain. We should start a club for homeless ZR-1's. Forgetting tools is the least of my problems. My Z is my only car now so if I don't bring it, it don't get dunn!
Bob, I got a SES light the other day & it turned out to be 61, 2* trouble. My scanner will not do all the tests that a Tech1A does so I had no choice but to do the flow chart without doing the required functional test. And.....after all that it turned out to be the ECM!
Well at least I passed my refresher course on plenums 101....it was easier the second time around! But I look on the bright side, at least I confirmed that my CCVB cover no longer leaks!
Well time for a shower & a good test drive.....it's a good thing that I have bad luck with vettes & keep a small cashe of spare parts!
Old 08-12-2007   #5
Test drive report:
I now have a vette again, not some car that just looks like a vette!
Old 08-12-2007   #6
Jeffvette
Tom, keep in mind all the pieces are aluminium and they get a little softer when warm.
Old 08-13-2007   #7
Norsky4360
I'd wait until it has cooled down enough for the coolant pressure to be almost gone. Then crack the expansion tank cap to relieve the rest of the pressure.
When I was doing my 'very last first' plenum pull someone shared a tip to drain the coolant from the expansion tank rather than drain everything via the radiator. Naturally I saw that after I'd already drained the radiator. I'll have to dig a little to find it.
Norsky4360 is offline   Reply With Quote
Old 08-13-2007   #8
Thanks guys. Yea what I did was some other stuff that was bothering me and by the time I was dunn there was no psi left in the coolant sys. & the coolant was just barely warm to the touch. Man these motors retain heat for awhile!
Jeff, I should remember that for the future! I was thinking that there was a slight chance of having things warp if I started to take stuff apart while still too hot. That's what kills me about the diagnostic charts in the 6E section.
"Scan motor in closed loop, does the scan report 2* vac @ .74v? Yes, pull plenum and test connector @ solenoid by shorting A & B leads."
Some non- trained backyard type like me sees that & thinks "how long do they wait to pull the plenum"? But I fixed the rattle from my front calipers and then tackled the plenum!
I should have swapped the ECM 1st just for sh*ts & giggles and I could have saved the labor. I think I learned something. The rapidity at which the DTC re-set itself should have tipped me to an electrical issue. I would clear it using the scan tool and it wouls re-set within 5 seconds. Oh well.
Hey, do we all know anyone reliable that repairs ECM's????
Old 08-13-2007   #9
Belsy
Belsy's Avatar
Many years ago a friend pulled his dual quad system off while warm and it warped so bad he could not re-use even after planing the surfaces.
WAIT and enjoy the result!!
Belsy is offline   Reply With Quote
Old 08-13-2007   #10
Belsy
Belsy's Avatar
Question Re: Plenum Pull Q's
On this note, what is the concensus on coolant by-pass on plenum & throttle body??
