Old 03-19-2015   #21
Default Re: Taller tires screw up asr???
For those looking at wheel spacers.
http://wheeladapter.com/wheel_spacers.php
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-19-2015   #22
Originally Posted by Bolling View Post
Will it hurt anything if I just run it with the codes each time.
Will the ASR and ABS still work properly?
Actually ASR and ABS are working properly, meaning the computer thinks there is an issue so those systems are deactivated..
once you correct the % difference front to rear, it should 'correct' itself and the lights will shut off
Old 03-19-2015   #23
JimZRyd
JimZRyd's Avatar
Just came across this thread, so I have a question... I'm about to pull the trigger on a set of Fikse Profil 5's in 18/19 sizes. Going with 345/30/19's in the rear. Been torned between 285/35 and 295/35 18's for the front. Only .3 inches in height difference. Anybody got any advice? Much appreciated.
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 03-19-2015   #24
Bolling
If you go with the 345's you might have the same problems I'm having throwing codes. After some research I think the perfect combo is 325/30/19 rear and 275/40/18 There is only a .1% difference and your combo there is a 3.8% difference. My rims came with the 345's but if I was buying new I would go with combo mentioned and definitely not the 345's
Bolling is offline   Reply With Quote
Old 03-19-2015   #25
JimZRyd
JimZRyd's Avatar
Maybe but I feel a 275 front is too small and there's nothing cooler than a big fat 345 outback! Many guys out there with a 285/345 combo and no problems. I'll go with one or the other. More than likely the 285.
Jim Zorgias
Old 03-19-2015   #26
Bolling
Good luck
Old 03-19-2015   #27
JimZRyd
JimZRyd's Avatar
Thanks. To you as well. Actually haven't heard anyone that has the combo I'm looking at mention anything about codes. I'll let you know how mine works out👍
Jim Zorgias
Old 03-19-2015   #28
Jagdpanzer
Jagdpanzer's Avatar
I tried 285/40R18 on the front and though it did solve the ABS/ASR alarm light problem I just couldn't stand the "thick" look of side wall.
From my experience if you want to avoid the potential ABS/ASR issues I would recommend 285/35R18 fronts, 10" wheels with 60mm offset and 325/30R19 rears, 12" wheels with 37mm offset. As several have mentioned with this combo the difference between front and rear wheel speed is within the erro band tolerated ABS/ASR systems. Running the Michelin Pilot SS 345/30R19 rear tires which are a little on the plus side dimensionally I had to trim the wheel well liner in couple places and cut down the heads of the forward lower dog bone bolts about 1/8" so they would not rub on he inner sidewall of the tires during hard cornering.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Last edited by Jagdpanzer; 03-19-2015 at 07:18 PM. Reason: Added 345 Michelin pilot SS info
Old 03-19-2015   #29
Bolling
Here is a few pics
Old 03-19-2015   #30
Looks great
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
