Old 03-17-2015   #1
Bolling
Default Taller tires screw up asr???
I just installed a set of C6 Z06 on my 92 ZR1. The rear tires are much taller and now I'm getting service ASR and service ASB. Are the taller tires the reason or is it something else?
Bolling is offline   Reply With Quote
Old 03-17-2015   #2
mike100
Default Re: Taller tires screw up asr???
Possibly... assuming that you did not increase the diameter of the fronts in the same proportion.
Old 03-17-2015   #3
Bolling
I'm sure there not the same proportion.
Old 03-17-2015   #4
Mine does not and I am using same wheels w 285/18F an 325/19R tires. My rear tires are about an inch taller than stock.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-17-2015   #5
Bolling
Mine are front 275/35/18 rear 345/30/19
Old 03-17-2015   #6
Bolling
What size spacer are you running in the rear?
Old 03-17-2015   #7
98indypacer
Almost 6% revs/mile difference may be a problem for ASR.
Diameter
Front = 25.6
Rear = 27.1
Difference = +5.9
Width
Front = 10.83
Rear = 13.58
Difference = +25.4%
Sidewall
Front = 3.79
Rear = 4.07
Difference = +7.4%
Circumference
Front = 80.3
Rear = 85.2
Difference = +6.1%
Revs/Mile
Front = 788.9
Rear = 743.2
Difference = -5.8%
98indypacer is offline   Reply With Quote
Old 03-17-2015   #8
Bolling
Diameter
Front = 25.6
Rear = 27.1
Difference = +5.9
Width
Front = 10.83
Rear = 13.58
Difference = +25.4%
Sidewall
Front = 3.79
Rear = 4.07
Difference = +7.4%
Circumference
Front = 80.3
Rear = 85.2
Difference = +6.1%
Revs/Mile
Front = 788.9
Rear = 743.2
Difference = -5.8%
Is there any way of fixing it through the computer?
Old 03-17-2015   #9
Jagdpanzer
Jagdpanzer's Avatar
The constant difference between front and rear wheel speed is to much (more than 4.5%) which triggers the ABS and ASR systems check lights.
I had the same problem after changing to my Fikse wheels with staggered tire sizes 285/35R18 fronts 345/30R19 rears. Solved the problem by machining a set of 50 tooth count ABS reluctor rings for the rear spindles which compensated for the diffence in wheel speed the ABS and ASR systems see. Now life is good again.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-17-2015   #10
18mm
