Old 03-06-2015   #11
Default Re: Fuel Rail/Fuel Pressure Regulator
What about the hat style itself, the soft, black denim. Is that still the preferred type? Maybe "Beanies" are the thing at the moment, especially for the NE part of the country.
I love the current hat "style"
Old 03-06-2015   #12
The Topic is Fuel Rails......
Not Hats.....
Wait a minute.......if the Topic is Jerry.....Hats Off To Jerry
I could not survive without Jerry .....and that is NO JOKE
That is a very nice Base Ball Cap for sure.......I would look good in that while holding some LT5 bolts.
Say Jerry.....speaking of hats and bolts.....you will receive a Box full of Cam Cover bolts on Monday.....just send me Hats (exactly like below) for whatever you think the Cam Cover Bolts are worth
Old 03-07-2015   #13
phrogs
phrogs's Avatar
I have a fuel rail that needs rebuilt. Only because it was apart when I got the motor it's from.
Let me dig up a photo for ya
JOHNNY P
Currently own
Old 03-07-2015   #14
Jerry,
Brings hats for sale to BG. I'd like one.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-08-2015   #15
Default Fuel Rail/Fuel Pressure Regulator and Caps
OK......I can put it back together
Me also on the current Hat style (Jerry's)
But I see NO finger smudges on the Hat Bill of your hat that might indicate some original bolt handling or other mechanic work
I have a case of Simple Green Spay bottles and Paper Towel nearby maybe like you do
Old 04-11-2016   #16
zr1pr
I am looking for a Fuel Pressure Regulator and I am assuming the whole Fuel Rail with the hard lines/connectors/"O" rings between the Regulator and Rails. Ran into a Fuel Pressure Regulator Failure yesterday with Raw Gas sucked into the Plenum. It is Rare but Happens
I have not figured out how to take a Fuel Pressure Regulator apart but apparently the air controlled valve/bellows totally failed with raw gas being forced out through the vacuum port and sucked into the Plenum from the Fuel Rails.
What a coincidence! just recently I was troubleshooting what seems to me as if the car was choking in addition to a Code 31 (cam sensor). The sensor checked OK but as I was disconnecting the MAP sensor to inspect it, I pulled the vacuum connector to the Fuel Pressure regulator and noticed fuel coming out of it.
Please help me make sense of what's happening to me. What were the symptoms your Z was experiencing? What was the car doing that made you look into the pressure regulator?
Thank you so much!
zr1pr is offline   Reply With Quote
Old 04-11-2016   #17
Thank you so much!
Ran into a Fuel Pressure Regulator Failure with Raw Gas sucked into the Plenum. It is Rare but Happens
Apparently the air controlled valve/bellows totally failed with raw gas being forced out through the vacuum port and sucked into the Plenum from the Fuel Rails.
Fuel coming out of the Vacuum Port on Fuel Pressure Regulator indicates a failure of the "bellows"/valve. Just hard to find a Fuel Pressure Regulator.
Old 04-11-2016   #18
Jagdpanzer
Jagdpanzer's Avatar
I've run into this issue a couple times myself.
Nothing you can do with the failed regulator but replace it with a good one.
Expect we will be seeing more occurances of this failure as the fleet ages.
Hope Jerry is working on a replacment for us before all the stashed OEM spares are used up.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-12-2016   #19
zr1pr
Please tell me the pressure regulator can be replaced without pulling the plenum!!
Old 04-12-2016   #20
Don't throw the old regulators away. The replacement, when my inventory is gone, will probably be an adjustable rebuilt core.
