Old 02-20-2015   #21
Default Re: New Wheels
Here are the wheel studs I have using spacers. ~$50 for the two sides
http://www.fmsrperformance.com/index...product_id=218
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-20-2015   #22
RussMcB
Nice! I was hoping someone would chime in with a good source. Thank you.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 02-20-2015   #23
batchman
Originally Posted by RussMcB View Post
I'm wondering why some people choose adapters over longer studs and spacers. Is there some sort of advantage? Seems like longer studs would be simpler (in design), stronger and safer, plus you're not limited to a minimum thickness.
Originally Posted by RICKYRJ1 View Post
I chose the adapter route because if I wanted to install new wheels with the correct offset (OEM/aftermarket) I wouldn't have to change the studs for a 2nd time. It takes less than a minute to remove the adapter.
I went with studs and spacers (5/8" IIRC) because lightness and simplicity are important to me. I actually use them with the OEs (street/rain), my CCWs (race rubber), and my clone A-Molds ("school" race rubber). The only pain with the studs is the rate at which I change rear hubs.
I use them with the OEs because one time I did an "away" event and with all the hassle of getting my race rubber & jacks etc there, I forgot the spacers. Missed half my runs that day. So I leave 'em on, no clearance trouble.
And now that I think about it, leaving them on with the OE wheels means I don't have that much extra length to run the lug nuts. If you can't guess, I change wheels more often than some folks change socks.
Much is made of hub- vs lug-centric mounting; I believe I routinely hit >1.5g cornering on my A6s and those wheels are lug-centric only. On the other hand I do have the re-torque religion due to swapping 'em so often.
Cheers,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 02-20-2015   #24
RICKYRJ1
RICKYRJ1's Avatar
Originally Posted by Bolling View Post
thanks for the info. Are your adapters aluminum?
yes
