Old 02-19-2015   #11
Roadster
Roadster's Avatar
Default Re: New Wheels
As with everyone else, looks great......
they make your Z stand out, need some close up pics whenever you can.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 02-19-2015   #12
RICKYRJ1
RICKYRJ1's Avatar
Originally Posted by Bolling View Post
I think I am going to try that. The only problem is the smallest I have found is 1 inch but I am going to try it.
Yes they are 18 and 19.
I sent my adapters to Carter at CT Machining he turned them down to the exact size I needed/wanted.
Old 02-19-2015   #13
Originally Posted by WVZR-1 View Post
I'm quite sure I pointed out the stainless caps a very long time ago for you. Your wheel nuts are M24-2 external OR what?
Wow that would be great. Let me check out the lugs and see about getting back to you.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-19-2015   #14
Bolling
When you bolt on the adapter what do you do with the stud that is protruding past the one inch.
Bolling is offline   Reply With Quote
Old 02-19-2015   #15
This is where I got my spacers.
http://www.wheeladapter.com/wheel_spacers.php
I wanted something that was BOTH WHEEL and HUB centric. I can tell you that when I go to remove rear wheels, these spacers are locked into the wheel.
No slop.
Again, mine are 18mm thick.
Old 02-19-2015   #16
BTW, looked at the lugs. All I could see is the word METRIC and then SF 9.
Old 02-20-2015   #17
RICKYRJ1
RICKYRJ1's Avatar
I just trimmed about a 1/4" of the stud off flush with the adapter. I have had them on now for several years with 0 issues, I believe I paid around $100 for the 2 rears
Old 02-20-2015   #18
RussMcB
I'm wondering why some people choose adapters over longer studs and spacers. Is there some sort of advantage? Seems like longer studs would be simpler (in design), stronger and safer, plus you're not limited to a minimum thickness.
Also seems like longer studs would be cheaper, too, but I haven't found them at reasonable prices yet.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 02-20-2015   #19
RICKYRJ1
RICKYRJ1's Avatar
I chose the adapter route because if I wanted to install new wheels with the correct offset (OEM/aftermarket) I wouldn't have to change the studs for a 2nd time. It takes less than a minute to remove the adapter. I bought quality adapters and have never had an issue with some hard driving on them.
Old 02-20-2015   #20
Bolling
thanks for the info. Are your adapters aluminum?
