Old 02-08-2015   #1
Default TPS failure
About 2 weeks ago my Z started to miss badly around 2500 to 3200 rpm. Since I Threw in a set of old FR2LS plugs after the the rebuild, I replaced plugs with NGK Laser iridiums. That had no effect. So, I tried another MAP sensor I had - still no fix. So, I was figuring either bad coil/coils or secondary fuel pump. However, I noticed miss was occurring immediately after cold start before being fully warmed up - may be not a fuel pump issue... What was interesting was that the miss would star exactly at same rpm range - between 2500 to 3200 rpm. This led me to suspect flat spot on the TPS sensor. Replaced it and sure enough, she runs fine!
I will confirm this later when I can hook up Jim's Tech 1 but I suspect voltage reading will start at .54 volts and as accelerator pedal is depressed progressively, voltage increase would drop or go to zero and then pick back up.
Thought I would share this other Z owners for future reference.
Old 02-08-2015   #2
Arctic91
Arctic91's Avatar
Default Re: TPS failure
So, I guess you won't be keeping that old TPS on the shelf as a spare after all.
Scott
[B]WAZOO Member[/B]
[B]'95 Callaway SNAT 450 Aerobody Coupe - Black/Black[/B]
[B]'92 Callaway SNAT 400 Convertible - Polo Green/Beige[/B]
[B]'91 ZR-1 #1231 - Arctic White/Saddle (SOLD)[/B]
[B]'90 ZR-1 #2547 - Turquoise Metallic/Black[/B]
[B]'89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black[/B]
[B]'85 Corvette 454 Coupe - White/Red[/B]
Arctic91 is offline   Reply With Quote
Old 02-08-2015   #3
Billy Mild
Where can you get TPS sensors at for these old birds?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 02-08-2015   #4
Jerry's Gasket.
Old 02-08-2015   #5
Scott
Jim and I am going to hook it up and check what happens to voltage as the gas pedal is depressed progressively with Tech 1 hooked up. This should teach us what to look for with Tech 1 when diagnosing a car with stumbling issue to verify TPS functionality.
Old 02-08-2015   #6
When you replaced the TPS, did u adjust it to .53-.57v w key ON?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-09-2015   #7
Yes. .54 volts.
Old 02-09-2015   #8
Scrrem
Scrrem's Avatar
You will have to show me sometime how you set that. I guess a tech 1 will make it easier.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-09-2015   #9
You should get a smooth sweep of voltage as throttle opens. If voltage changes in "jumps" or not at all, then it's a problem. If you have the TPS you replaced, you can just use a DVM to check it. Can also use the DVM to check the one on the car by using jumper wires between the harness and TPS. Feed the 5v reference signal to the TPS,then connect DVM to Ground and TPS signal lines.
With key ON, you can loosen two screws holding TPS to throttle and adjust up or down to set voltage in specified range. Then tighten and re-check. Flip the throttle a few times to make sure throttle is seated properly. Scan tool definitely makes this easier to do.
Old 02-12-2015   #10
rkreigh
ahhhh the tps
in the old days with my turbo buick these things would forever go out of adjustment and it was important to get the wot volts above 4.7 or the ecm wouldn't give you the full power
we were always grinding out the slots and tinkering with them
then some gent came up with "tps enhancer" boxes that would trick the cpu and change the ramp up curve and max voltage to get more mid range torq from the turbos
never had one go bad, but I sure thought they were
congrats on it being an ez fix
95 390 LPE ZR1 (505 rwhp)
