Old 01-21-2015   #11
Default Re: Changing oil...Let it drain overnight ?
I pre-fill the filter, and with a little practice one can flip it over and place it onto the threaded post - in one quick motion, and usually not spill a drop. But, if you do, that's why God made rags!
Pre fill the Filter ??....I am not so sure why given all the potential mess involved......
I have found that Camshaft bearings and rod bearings maintain oil for a very long time with engine not running (like years).
The Lifters also maintain oil on their surfaces for a very long time as do the Cams.
Likewise the Chain Guides maintain oil for a very long time. The Chain tensioners will bleed back oil but it has been said that Start Up Loose Chain guide slap is just a noise and no harm and no foul mechanically. Having said all that......pre-filling the filter definitely does not hurt the engine in any way
Old 01-21-2015   #12
But - but - but...Thar ain't no PRESSURE on that residual oil, doanchaknow! Not filling the filter means it takes longer before the pressure comes up, an deez dern 1990s rev to 1800+ on fire-up and hold for a couple seconds before idle slows down to settling. The sooner I see pressure, the better, at least that's how I feel.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-21-2015   #13
Yep.....you are correct on those start up revs for sure......and concur on seeing the oil pressure build up as quick as I can.
Old 01-21-2015   #14
RussMcB
Default
So, do some filters let you pre-fill with oil, turn them upside down and the oil doesn't pour out (all the time while you're spinning it in place)?
Yesterday I bought a Napa Wix 1324 filter and will be changing my oil this week. It's hard to imagine not making a mess.
I've always prefilled oil filters in the past, but I've never had a car with the OF on top of the engine upside down.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 01-21-2015   #15
Roadster
Roadster's Avatar
The best way to install a pre oil filled filter for the LT5 is to turn the car upside down, that way you won't spill a drop....I'll just leave it at that.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 01-21-2015   #16
mike100
I could see just pouring enough oil into a new filter to saturate the filter media which might facilitate a quicker flow-thru when the flow of oil fills the empty filter can on start up. You could reasonably expect to be able to flip it and screw it on quick enough to not make a mess.
Plus if do it fast it will be a centrifuge of sorts and won't blurp out the threaded hole. Don't slip!
Old 01-21-2015   #17
Maybe there is a worthwhile market for LT5 oil change bib - you know, like the bibs they hand out when you go to eat crabs - anti-blurp bibs?!
Old 01-21-2015   #18
You guys.
Old 01-21-2015   #19
Fully Vetted
Fully Vetted's Avatar
That's all I do. I fill it about halfway up and set it to the side. Within minutes the filter media soaks most of it up.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-21-2015   #20
That's what happens. Flip it over fast enough and you won't spill any oil. You can just spin it on quick enough.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
