Old 07-18-2007   #1
72ZR1
Default oil leak
finely found it! had leak right front of engine leaking on frame and going everyware.after checking oil pan',the lower timing cover bolts were loose but not the leak.lower right front of engine it's called oil pump access cover bolts were loose.tighten bolts leak gone.gm manual supplement page 6a2a-6 #423 is the cover.it's a real bear getting to but you can from the top. hope it helps.
72ZR1 is offline   Reply With Quote
Old 07-19-2007   #2
Z Factor
Z Factor's Avatar
Thumbs up Re: oil leak
Any thread/post that informs fellow ZR-1 owners is always helpful.
Old 07-21-2007   #3
Default Re: oil leak
Second time I've heard of this leak. Thanks for posting a problem solution. Too often, all we get to hear about is the problem and the recommended fixes only.
Jerry
Old 07-21-2007   #4
Jagdpanzer
Jagdpanzer's Avatar
I looked up page 6a2a-6 #423 and couldn't determine exactly where this cover plate is located on the engine. Can you please provide a few more details or maybe even a photo?
Thanks for sharing this with the group.
Old 07-21-2007   #5
RedZR
RedZR's Avatar
Did you have to remove anything to get to it?
Dan
RedZR is offline   Reply With Quote
Old 07-21-2007   #6
Dan
I have a leak too, but haven't gotten to it yet. It bothers the heck out of me, but I don't know enough about the LT5 and don't want to screw anything up!
I'm with Dan, do you have to remove anything to get to it?
thanks!
Old 07-22-2007   #7
Here you go....
[IMG][/IMG]
Old 07-22-2007   #8
Jagdpanzer
Jagdpanzer's Avatar
Thanks Jerry, in this case your picture is worth a thousand words.
Originally Posted by A26B
Here you go....
[IMG][/IMG]
Old 07-23-2007   #9
flyin ryan
flyin ryan's Avatar
didn't think AB cars leak
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 07-23-2007   #10
72ZR1
thanks!
no but it's a tight fit
