Old 11-21-2014   #31
Default Re: LED foglight replacements
yes, lenses and reflectors changed in 1991..
Old 11-21-2014   #32
8cam
I know that. What I'm asking is, are the newer style lights worse than the 90s? Because my 90 style fogs perform quite well.
Old 11-21-2014   #33
Yes I would believe so due to that design change, also I think there was a wattage difference on OEM bulbs, but don't recall
Old 11-21-2014   #34
Originally Posted by Fully Vetted View Post
Actually, he did.
GC, did you not say "I found the same HID's at half the cost so I installed them".
They are LEDS not HIDS I corrected the post. HIDS will not work without a ballast
I edited the posted as I swapped LED and HID in one place on the post however, the title was LED foglight replacements. Sorry for that moment of confusion
To date there are no HID non ballast applications... however something tells me me somebody is working on it. I was not impressed with these in the daytime until I put them in the reflector housings and saw how clean they looked and performed in the dark.. way better on my 91.
Old 01-11-2015   #35
Nope. drop in replacement
Daryl,
May I as how the light pattern is? Close approximation as generated with OEM halogen?
Old 01-11-2015   #36
Daryl,
I think it's the same as the stock reflector is maintained but the source bulb is now a brighter whiter hue. GC
Old 01-14-2015   #37
efnfast
Anybody have the oem bulb number for the fogs in a 90?
Old 01-14-2015   #38
Original GM #: 9441728
it is also 880 (for replacements)
Old 01-14-2015   #39
efnfast
Thanks Jeff, that's what I was looking for . The replacement number. -Steve
Old 12-28-2015   #40
ZR1North
I am updating this very useful thread with my experience to date with exterior and interior LED replacement. I haven't tackled the foglights or headlights yet, but I thought I'd update this thread rather than start a new one since it is difficult to find info on LED conversions.
I have replaced most of my interior (non dash) lights with LED assys from SuperBright LEDs. The vast majority of their replacement LEDs assys are indeed plug-and-play, are excellent fits and the difference in brightness is astounding (I used cool white for all interior lamps). The only issue is with the replacements for the two mirror (map reading) lamps; the suggested replacements were too large for the holes in the mirror where the standard 168 bulbs are fitted from the factory. I am awaiting their response for a fix. Thus far, their tech support has been excellent as is their web site for helping with decision making.
As for the exterior, I used CorvetteHID.com for the tail lamp/brake light replacements (C4LEDTAILSTAND2) last year. Like SuperBright, CorvetteHID was excellent to deal with and the products are high quality. I had to replace the signal light flasher with an electronic flasher (c/w ground) to make the rear tail/signal LEDs work, but I did NOT have to replace the four-way flasher - UNTIL I converted the front park/signal bulbs to LEDs this past week. The signal lights continued to work ok with LEDs at all four corners, but the four-way emergency flashers were rendered inoperable with the recent change to the front park/signal lights. I will change out the four-way hazard flasher with an electronic unit next week, and I expect that will resolve the four-way emergency flasher issue. As for the other external bulbs, they were pretty much plug-and-play with the SuperBright replacements, except for the 1156s in the front corner (white light illuminated when the key and park/headlights are on along with the turn signals). I used my dremel tool to "trim" the 1156 sockets to accommodate the 1156 LED replacement. I notified SuperBright of the issue this evening and am awaiting their response before tackling the other 1156 replacements (backup lights and rear corner white lights ,which also illuminate on backup); I had to remove a lot of plastic in the sockets, so I don't intend to "dremel" the other four 1156 sockets at the rear.
Finally, I converted the CHMSL (3rd brake light) to LED using "=Jeff=" suggestion to use a 2005-2007 Chevy Uplander unit as the base (largely because the Uplander assy has essentially the same height as the ZR-1 CHMSL assy). You have do some mechanical work (cut - shorten- the Uplander LED strip and clear lens, and reattach the clear lens to the LED strip), and you have to do some rewiring due to the mechanical changes, but it fits very snugly into the CHMSL housing and looks great (Jeff has pictures of his conversion on this site). It's also a snap to change it back to original if one should decide to do so at any point.
The changes in brilliance and longevity of the LEDs are definitely worth the effort but it takes research, time and effort, so others' experiences will be helpful to those that follow as well as those of us requiring another few yards to get the 1st down.
Cheers
ZR1North is offline   Reply With Quote
