Old 11-01-2014   #1
mtown
Default ZR1 Not available
Not available.
mtown is offline   Reply With Quote
Old 11-01-2014   #2
Default Re: 1992 ZR1-Part Out
Interested in the Engine with Bell Housing, Flywheel, Clutch, Pressure Plate
(including ECM and Distributorless Ignition System Module attached under Plenum and coils).
Also interested in Transmission.
.......and some other stuff
Including Bose radio/CD, Bezel, Climate Control, and Instrument cluster.......
I would pick up (no shipping required).
Old 11-02-2014   #3
phrogs
phrogs's Avatar
Those seats might be toast, since parts were left sitting on them. kinda becomes memory foam.
JOHNNY P
Currently own
Old 11-02-2014   #4
cvette98pacecar
PM Sent
Old 11-03-2014   #5
mike100
If I send you an empty box made for shipping corvette targa tops, how much do you want for the removable roof (minus shipping-estimated to be $60-$70).
Old 11-04-2014   #6
batchman
Sounds like the steering column is missing? If not, I'm interested (presuming it was not damaged). I don't need the steering wheel or shaft, just after the tilt mechanism really.
I would also be interested in the brake master cylinder, brake booster, and brake pedal & mechanism. This is so I can convert my 91 to a 92 brake system. The pedal and mechanism are not ZR-1 specific parts but you happen to be parting a year of C4 that works for me.
I would think these items could be boxed/ground shipped reasonably easily and should be easy to remove if the seats are out.
Condolences on the loss of the owner.
Cheers,
- Jeff
Old 11-08-2014   #7
BigIke
FX3 shocks?
BigIke is offline   Reply With Quote
Old 11-08-2014   #8
Billy Mild
What kind of headers are those? They look like long tubes.
Any dimensions at all? I may be interested in them.
Old 11-09-2014   #9
no idea I thought those looked stock with the air tubes
Old 11-09-2014   #10
mtown
UPDATES TO LISTING REFLECTING INFO ON SEATS AND HEADERS MADE.
