Old 10-02-2014   #1
Default Power steering line routing
Anyone have a pic of the Power steering line routing on a 91 or later ZR-1, trying to put the lines in the 91.....referenced my 1990 and its a totally different hose setup
HELP!
Old 10-02-2014   #2
Default Re: Power steering line routing
HELP!
Stand by. Going to the garage now...
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-02-2014   #3
This is the high pressure hose similar to my 90
After searching through a few things, the hose on the right is what was on the car...the PS failure was apparently due to hose rub
Old 10-02-2014   #4
I believe the hose that was on the car is a 93-95 hose as is the low pressure hose to the cooler. The hose on the car goes under the sway bar where the 90 goes over.
Old 10-02-2014   #5
Now I need to know the orientation of the upper hose.....on the 90 the low pressure hose is on the bottom and the high loops over the top.
Anyone know if this is correct?
Old 10-02-2014   #6
I looped the hose to the back as I couldn't see if looping to the front with the pulleys
Old 10-02-2014   #7
WVZR-1
'90 and '91 PS pressure hose is the same. There's a different part number for '92+ cars.
The return side is the same all model years.
In this buyers guide a 71777 is '92+ part and 71778 is the '90 & '91 part:
http://www.plews-edelmann.com/pressure-hoses/
Click the part # for images.
Old 10-02-2014   #8
Hope this helps off on 91. not an easy pic to get! If not from the right angle let me know I'll try again.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-02-2014   #9
hmmm....my 90 is totally different than those....and this hose set up seems to be off of a 93-95. Odd
Thanks Steve & WV
Old 10-02-2014   #10
Pardon my rust....148Kmiles
