Old 09-15-2014   #1
efnfast
Default Short throw shifters and lift ring.
When you replace or modify your shifter, what do you do about a reverse lock out? Seems like it would be tough to go from 5th to reverse, but Bill B says it can be done up to 80 mph, once.
Old 09-15-2014   #2
KILLSHOTS
Default Re: Short throw shifters and lift ring.
Bill just installed one of his lift-ring shifters on my car a couple months ago. I was under the impression that the crash-through detent on the later models was a function of the transmission itself, not the shifter. So even if you could install a non lift-ring on an early car, you'd have no crash-through feature and that would be VERY dangerous indeed. Hope this helps.
Old 09-15-2014   #3
zrss
I had Bill shorten the original shifter but maintain the reverse lock out. Best of both worlds, in my view.
zrss is offline   Reply With Quote
Old 09-15-2014   #4
efnfast
Short throw and short shifter, or just short shifter?
Old 09-15-2014   #5
zrss
Just short shifter. I would expect that short throw and short shifter would require more effort to shift than I was looking for.
Old 09-15-2014   #6
dredgeguy
dredgeguy's Avatar
Not to worry, you will get used to not having the lock out. I do not have one on my Hurst and while I am careful from 5 to 6, never needed to do a very fast shift in that area. Once I am in 3rd, am home free dusting somebody off.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-16-2014   #7
efnfast
Somebody explain the "crash through" feature. Is it part of the shifter, or part of the tranny.
Old 09-16-2014   #8
WVZR-1
The '95 crash-through has internal transmission/shifter differences.
There was actually even a TSB/Recall that effected the first few LT5 builds in '95 regarding "unable to shift into reverse".
The TSB/recall is referenced here at the CAC:
http://www.corvetteactioncenter.com/...ssion-592.html
Old 09-16-2014   #9
5ABI VT
I have the Hurst on my 94 black tag (later style just built in Germany), and its quite easy to go to reverse. So easy in fact I would have to make sure I keep an eye if someone else were to drive the car and I even have to pay attn myself even shifting easily. Not too happy about it but 6th is just a fuel mileage gear anyways so like mentioned above.. its a slow easy shift once relaxing anyways.
Old 09-16-2014   #10
mike100
My C4 before my current ZR was a 95 coupe w a 6 speed. I liked the crash-thru so much that I had Bill B. convert mine during the rebuild of my black tag gearbox. I guess I was already accustomed to no lift ring. It does require a good effort to find reverse, it won't be flying in there under the shifter's own weight and inertia like the early style without the lock ring.
