08-31-2014 | #1 |
Can the LT5 experts fill me in on.....
Ok, I think I have an idea why, but am not really sure, so can the LT5 experts who have the knowledge and understanding of this engine explain the following to me....
Why is it that if you let the Z sit for a week or even two weeks before you start the engine, that there is not any chain rattle upon first start-up??? I understand why there is chain rattle during some restarts, and that there is a kit available (which I have) that once installed, eliminates that problem or almost completely eliminates the problem. We had the Z out today, and first start-up, no noise, most restarts after that the dreaded chain rattle..... Just trying to learn more about the system......thanks for any info........
08-31-2014 | #2 |
Re: Can the LT5 experts fill me in on.....
No expert here but it sounds like you have a good check valve in your oil filter.
I have no chain rattle on my 91 or 93 even if they set many weeks. Both have Blue GM filters.
08-31-2014 | #3 | |
I also have a Blue GM filter. Hopefully over the winter I will attempt to install the kit for this, just have to see what the time factor allows me to do....as there is always something going on........
09-01-2014 | #4 |
Mine went away years ago after my second synthetic oil change. I use the blue PF970.
09-01-2014 | #5 |
chain rattle is annoying but not harmful. I don't even notice it anymore
09-01-2014 | #6 |
I barely notice it and that is only if the car sits for a long time. Also the car starts quicker (or at least seems to) if I turn on the ignition first wait about 3 seconds then start.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
09-01-2014 | #7 | |
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 09-02-2014 at 02:36 PM. |
09-02-2014 | #8 |
I've been using the white "Napa Gold" filters that are made by Wix and they have a great anti drain back valve. Zero rattle.
09-02-2014 | #9 | |
I noticed that if I turn the key without starting 2-3 times (did it to intentionally to move the pulleys a bit) when I actually start chain rattle was severe which never happens on daily normal start. I concluded that when I ran the motor w/o starting oil in the tensiners were being drained and w/o actually running were not replenished w/ system pressure. Just my theory. |
09-02-2014 | #10 | ||
Either am I, but what you are saying makes sense to me. I have to go out soon and will take the Z to run my errands. Will report back later. The Z has sat for 2 days, so we shall see!!!
