Old 08-31-2014   #1
Roadster
Roadster's Avatar
Default My latest mod!!!
Still learning about the LT5, so I decided to add this item to avoid the possible collapse of the air duct during high rpm operation, I purchased this part. Although we have specific vendors that carry parts for our vehicles, and I have supported them recently, with that being said, I found this part on the "bay".
Had a good write-up and some of you may have already purchased this or know of it.
Took a good 20 minutes to get it installed, and it feels and looks like it will work very well. No way anything is going to collapse with this installed.
BTW, I never told you guys that I own multiple, yes multiple ZR1's and also another ZR-1 (a 95), only thing is they are attached to the wall......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-31-2014   #2
Default Re: My latest mod!!!
I use one of those also. Bitch to install.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-31-2014   #3
Roadster
Roadster's Avatar
Yes it was, but got it done......so you used to??? was it on the ZR-1 that you sold?
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-31-2014   #4
Racinfan83
Link please??
Old 08-31-2014   #5
No. Got it for 458. I'd also made one from aluminum sheet using pop rivets.
Sort of wonder if the thickness of the phenolic reduces amount of airflow vs. The aluminum. On the other hand, the phenolic is smoother with fewer protrusions into the airflow (ie. rivets and seam).
Old 08-31-2014   #6
PhillipsLT5
PhillipsLT5's Avatar
Another option, hoops from Marc
Old 08-31-2014   #7
Fully Vetted
Fully Vetted's Avatar
Geeze... I thought you were saying you got it for your 458. As in Italia 458! Then I realized you were talking of your Black Rose beauty!
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-31-2014   #8
Roadster
Roadster's Avatar
Originally Posted by Racinfan83 View Post
Link please??
no problem I will send you a PM with the info.......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-31-2014   #9
Roadster
Roadster's Avatar
Well went for a ride this AM and by the way the 94 performed, I would say that there was not any hinderence of air flow what-so-ever........
Very happy with the mod, glad I did it........
Yes, saw that, but I liked the insert better, you do have to undo the air assembly for easy install of the air duct, but no biggie, and priced the same.
Marc, has great products, his chip is fantastic......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-01-2014   #10
edram454
edram454's Avatar
good mod. I did it months ago. Not to hard to install and my air bridge is solid. this thing will never collapse.
