Old 08-21-2014   #1
Okiedoke
Okiedoke's Avatar
Default Help identifying parts
On my last trip to the mechanic, he pointed out a couple of things under the hood that he suggested I follow up on. One was that he noticed I'm missing a cover of sorts. I've circled it in red below. Does anyone know what this is called and where I could get one?
He also had to replace the bolt below with one that's different but had the same thread. Does anyone know where I can get the right bolt?
Thanks.
1991 ZR-1 #405 (white/black with blue pin stripes)
Okiedoke is offline   Reply With Quote
Old 08-21-2014   #2
phrogs
phrogs's Avatar
Default Re: Help identifying parts
You need the two nuts and one screw for the throttle body cover as well, I can't recall the official name but I doubt I have one of these, I might but doubt it. Check jerrysgaskets.com
And ebay as well.
That bolt someone has one . Jerry should
JOHNNY P
Currently own
Old 08-22-2014   #3
Okiedoke
Okiedoke's Avatar
Does one of these look like the correct bolt?
1) Bolt, MAP Sensor to Bracket, NEW 90~95 [6.5B]
2) Bolt, MAP Sensor Brkt to Plenum, NEW,90~95 [6.5A]
Thanks.
Old 08-22-2014   #4
Z06scentair
Z06scentair's Avatar
Originally Posted by Okiedoke View Post
Bottom item is what you need.
bracket to plenum bolt.
Old 08-22-2014   #5
phrogs
phrogs's Avatar
Yep the small one is the one you need.
JOHNNY P
Currently own
Old 08-23-2014   #6
mike100
I replaced my map sensor bracket bolts with flange head 10mm bolts. Way easier than finding a torx bit and then trying not to drop the slippery bugger (which is probably the reason you have different hardware now-no biggie).
Old 08-27-2014   #7
Okiedoke
Okiedoke's Avatar
Actually, while working on the car, the mechanic just happened to notice that original bolt was either broken or about to break, so he replaced it with the only bolt he had available with the same thread.
Old 08-27-2014   #8
Okiedoke
Okiedoke's Avatar
Thanks! It never ceases to surprise me the knowledge on this forum!
Old 08-27-2014   #9
Okiedoke
Okiedoke's Avatar
And ebay as well.
Jerry confirmed he didn't carry the cover. I found and ordered a NOS cover at White Racing Products. (Ouch, it's $$$!) They didn't carry the nuts and screw. Jerry's out of town this week. Will check with him to see if he has the nuts and screw next week. In the meantime, if anyone knows the right nuts and screw, would be appreciated.
Old 08-28-2014   #10
WVZR-1
Jerry should have nuts (16512106) and the screw (11514501).
The nuts are M4 X 0.7 with a flange, the screw is a self tapping M4.2 X 1.4 x 8 with a torx pan head. I'd think there's no rush so wait for Jerry or just place the order on-line and I believe the store is being "attended to"!
