Old 07-14-2014   #1
USAFPILOT
USAFPILOT's Avatar
Default Antenna Mast Replace
I resurrected an old three in the tech section, but I kinda hoped for help tonight on removing an antenna mast. I have the instructions, and have removed the nut (after trashing the grommet). How does the mast now come out. It is in the up position. It will not pull out or come out on its own. I cannot see the contact spring described in the instructions.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
Old 07-15-2014   #2
USAFPILOT
USAFPILOT's Avatar
Default Re: Antenna Mast Replace
I have the whole antenna motor mast assembly out and on the bench. How does it come apart? I still can't get the mast out. It looks like it has plastic rivets or something holding the case together.
Old 07-15-2014   #3
WVZR-1
There's likely a label on the antenna with a part # on it. What is the number on the label? A snapshot of your antenna?
Old 07-15-2014   #4
You need to grind the head of the plastic rivets. After service grind down flush and use sheet metal screws to reassemble.
Old 07-15-2014   #5
USAFPILOT
USAFPILOT's Avatar
i am just sending the mast back and getting an entire new assembly. Its easier for me. Thanks though.
Old 07-15-2014   #6
Yep that is what I did as well but still have been lazy and not installed it yet.
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 07-15-2014   #7
USAFPILOT
USAFPILOT's Avatar
I was at my wits end mashing the grommet from the inside of the car out so the motor would come out...what a pita. I tried to take out the top grommet and it fell apart...so I have the new antenna and grommet coming from mid america, though its backordered. So the wait begins. In the mean time I yanked out my speaker amps, all 4 and am sending them to Dr. Don.
Old 07-15-2014   #8
Fully Vetted
Fully Vetted's Avatar
That's what I did as well. New one works perfectly.
Hey, I saw you got hammered with storms down there or maybe a tornado a week or so ago. Anywhere near you?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-16-2014   #9
USAFPILOT
USAFPILOT's Avatar
We got some serious T-Storms, but no tornadoes.
Old 07-17-2014   #10
Spartan1510
I ordered a replacement antenna assembly from Corvette World and they beat the other advertised prices and got it for me the next day. AC Delco part. After researching - I simply decided to replace the whole thing.
Delivered the car to Corey today for a few things and plan on doing the antenna when I get the car back.
Spartan1510 is offline   Reply With Quote
