I think my fuel regulator which is located at the rear of the plenum is bad. I removed the vacuum line to it today and forgot to put it back, then started the car and drove down the block. The car didn't run very well due to the vacuum leak, but I thought that with out the plenum vacuum the regulator should'nt let any fuel pass at all. So if this is the case... is it possible that it is not opening enough during high demand? Or is this just an open or closed type device with no actual regulation properties?
no actually you can plug off the vacuum part and get 4lbs increase in pressure . its an old lt1 trick . nothing is wrong with it at all just hook it up and go . or id she running bad?
#3 | |
![]() Join Date: May 2005
Tyler |
Thanks Tyler. This vacuum line is visible from the top of the plenum and the device it connects to has fuel lines running throught it. It is black and round with a small 1/8 tube connector on the top of it. A year or so ago I did some engine work and forgot to reinstall this vacuum line then too, and the engine would not fire at all.
The car runs fine with it all hooked up. I'm just trying to figure out if the car should fire up at all if this device controls fuel delivery.
![]() Join Date: Jun 2004
Yep, that is the fuel regulator.
Thanks Carter. So the engine shouldn't have fired with the vacuum hose removed...right?
Can't tell you for sure but I do know 100% that the unit is the fuel pressure regulator. Sorry I do not have an answer on the starting part
The vacuum line you pulled off actually raises FP when disconnected because the regulator vacuum port is now at 100% MAP. If anything you're running rich which shouldn't harm the motor. ECM will be pulling fuel out trying to get back to stoich.
#10 |
the car should start with the vacuum hose unplugged. but I dont know why yours didnt/doesnt?
