#31 |
If it was me, I would use an 84-85 C4 as my base. They don't have CCMs to deal w. My 84 Z51 weighed 3250 w fluids. So imagine throwing in a lightweight LSx motor. Then the EFI and the PCM selection would be pretty straightforward using something like the 411. No hood clearance issues. Just thinking out loud. This was something I considered before buying my ZR. At the time, it was a more difficult swap. But today, they have kits for this. I think ZF-Doc even has a way of bolting ZF to LSx motor. Maybe an LS7.
Then throw on a set of CROSSFIRE INJECTION belt line moldings. ![]() ![]()
#32 |
![]() Join Date: Jan 2010
"Then throw on a set of CROSSFIRE INJECTION belt line moldings"
Talk about unloved! I'd have Prius's lining up with me. Funny!!!!!! |
#33 |
![]() Join Date: Dec 2009
Alnukem,
Thank you No problem, my VD 368 has been out of the car for 3 years, I'm a slow Mover as well. It's funny that you want to put your BB into a zr1 and I want to Put an LT5 into a BMW 850, we'll have to exchange some pics If these projects come to fruition! Take care Ric young |
#34 |
Just a note for people that might use this thread in troubleshooting their car, I did buy Mitsumark's car last year. At the end of the day, it was collapsed oil rings & damaged sleeves. To be fair, I believe this car was tracked pretty hard. We have decided to replace the sleeves, rings & bearings. A little additional porting work will be done & Pete's Stage 1 Exhaust cams will be added to the already there, Split Duration 228/238 Intake Cams. I Hope none of you end up at the same place, but it could have been worse!
#35 |
cool once it is running right I'll give you 10k for it! i still think this was a super deal.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
#36 | |
I too still think it's a good deal. I'll have a rebuilt Ported 368 with cams & a free car with coil-overs & heim jointed suspension.....& how about this, the radio works! The stigma of the previous builder & cams condition will be behind it. It's kinda nice to know what is really in a engine, a lot of time the original owner looses specs, or the next guy. That info is going in a log that goes with the car. |
#37 |
![]() Join Date: Jun 2015
So why didn't the collapsed ring show up on the compression test, was it an oil control ring?
#38 |
#39 |
Were you able to diagnose the issue with the engine in the car? or was it found during dis-assembly. I assume the oil consumption and smoking reappeared and then you decided to open it an see. If you can diagnose a bad oil ring the car I would like to know how you did it, for a future reference that I never hope to need
#40 |
I bought it knowing it had issues. I tried a few things unsuccessfully, gassed it up & drove it to Chicago to give it to someone who knows something. The Mechanic tried a few things & the decision was made to remove the engine. If you think you have this problem, one of the imports are known for it & it's pretty common to run Risolene or I think, GM Top End Cleaner. Please do your research first.
