Old 05-12-2014   #1
Default Porting 93-95 Injector Housing
We all know the 93-95 injector housings are not as robust as the 90-92 when it comes to porting. But one area in particular you should watch out for are the primary runners next to the coolant outlets.
While you can feel the thickness of the runner easily, as the runner reaches the base of the injector housing it kicks in...lending itself to porting through or even worse porting thin and finding out the hard way.
Attached is a pic of the area....the weak spot is about as wide as a paperclip, but I would advise once getting toward the base you cease removing material and smooth out the port. Most likely you can get to 34mm although its not the 36 you can get to in the other runnners.... not worth the headache of going through
The area of the weak point is circled below
Old 05-13-2014   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Porting 93-95 Injector Housing
Thanks Lee, nice to know where the thin areas are.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-13-2014   #3
Man lots of typos in my original post.....
Old 05-13-2014   #4
That coolant port is a PITA even w the 90-92 IH.
