Old 05-06-2014   #91
Gunny
Gunny's Avatar
Default Re: Mountain Run 2
Originally Posted by Rex Ruby View Post
Bringing the 94 ZR-1
Thanks ... I assumed (dangerous, I know) that your Ruby was also a Z. btw, I really like your car tags ... seems you're almost "obsessed"
Gunny is offline   Reply With Quote
Old 05-06-2014   #92
nelson007
nelson007's Avatar
This is my first long trip with my Z. Can anyone suggest what tools to bring along and spare parts,
Thanks,
Nelson 007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 05-06-2014   #93
Mystic ZR-1
Mystic ZR-1's Avatar
Thanks,
Nelson 007
Not sure about spare parts and tools, you can't bring your whole toolbox and spare parts inventory with you. Whatever you bring for spare parts, won't be what craps out... But traveling in a group is always a good thing when in a 20+ year old car. (and we've got that covered!)
An AAA card is not a bad idea either.
FWIW: I carry a scissor jack, tire plug kit (a good "gun" type w/mushroom plugs), a can of Green Slime, tire guage, wire cutters (to pull out the nail or whatever), a small 12v compressor, gloves, flashlite and a breaker bar w/deep socket (for jack and lugs). It all fits in the compartment behind the right seat. Unless I tear a hole in a tire, with this maybe I can keep going. Check the air in your spare too, even though I'd try to avoid using it if at all possible.
See ya Sunday!
Old 05-06-2014   #94
Gunny
Gunny's Avatar
What Doug said ... plus
if you have a spare serpentine belt, it's a good idea to keep it in the compartment behind the seat.
I usually carry a small array of sockets, extensions, ratchets, wrenches, torx bits, etc. I picked up a couple of plastic tool boxes from Sears that hold most of what I need and are compact enough to carry easily ... I believe they are compact truck boxes Item # 00965117000P Model # 65117.
The nice thing about this trip is the number of knowledgeable "mechanics" available should anyone need some help.
Old 05-06-2014   #95
nelson007
nelson007's Avatar
Thanks for the suggestions. Your right about the knowledgeable mechanics, sad to say i am not one of them.
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 05-06-2014   #96
cvette98pacecar
I bring an alternator, serpentine belt, gaskets, coil packs, injectors and water pump. Tools of course.
Old 05-07-2014   #97
BigJohn
BigJohn's Avatar
Motorhome with a 35ft trailer?????????
Old 05-07-2014   #98
I'll have the usual-
  • sockets and screw drivers,
  • hex and torks bits,
  • hammer drill,
  • VOM,
  • scanner,
  • cleaning kit (Zaino stuff),
  • tire plug kit,
  • FRS spare (should anyone need to borrow a 2-way radio),
  • plenum gasket set,
  • torque wrench,
  • First Aid kit
  • Jack Daniels...(for later, of course!),
  • JB weld, Gorilla tape, WD-40
Old 05-07-2014   #99
Mystic ZR-1
Big John
Last nite you said you couldn't make the trip, this morning you're
coming in your motorhome and trailer?
Where did you get the trailer? Will the LM be on it?
D
Old 05-07-2014   #100
efnfast
Hey Gunny, have you made reservation's at the restraunts? 20 people is bit of a hit.
