View Poll Results: Which brand of street tires do you have
BF Goodrich 30 9.46%
Dunlop 3 0.95%
Goodyear 98 30.91%
Kumho 6 1.89%
Michelin 34 10.73%
Nitto 82 25.87%
Pirelli 4 1.26%
Sumitomo 36 11.36%
Vredestein 20 6.31%
Yokohama 4 1.26%
Voters: 317. You may not vote on this poll
Old 05-05-2014   #101
msorenso
msorenso's Avatar
Default Re: Which brand of street tires are you running on
Have a set of those BFGs on my 96 Camaro SS, hooked up well
msorenso is offline   Reply With Quote
Old 05-05-2014   #102
Vetman
Vetman's Avatar
Thumbs up Re: Which brand of street tires are you running on
Michelin looking for best handling and especially smoothest ride. Tire engineer tells me Michelin have most vertical flex in sidewall. And almost no following ruts or grooved pavement.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 05-06-2014   #103
8cam
Originally Posted by KILLSHOTS View Post
How wide are they, though? The problem with Sumis and Nittos is that, although they are technically 315s, they APPEAR very narrow on the car. That's why I want F1 GS-D3s or PS2s. If the MT was really fat, I'd consider it.
I don't understand this comment. The tires are either 315s or they aren't. The pic below shows the Nittos on the stock wheels and you can see they fit the rim exactly like they should, without the sidewall camber you'd see when mounting a 335 for example. Maybe you're talking about a more square shoulder?
In any case, the Nittos seem like a decent tire but definitely aren't my favorite by any means. They are a little noisy and I suspect don't have the same levels of grip as other choices. I'll know more after I can autocross them.
'90 ZR-1 #1322 Daily Driver, 64k and counting
Black/Gray
[IMG]http://i208.photobucket.com/albums/bb49/mlitherland/IMG_0326_zps3d50d8cb.jpg[/IMG]
Old 05-06-2014   #104
When I put a tape measure to my Dunlops the rear is around 12" wide on the rear and 11" wide on the front tire.
On my 84 Vette they were 10" wide on both front and rear.
I wonder if anyone has actually measured more than 12" wide on the rear footprint on their ZR-1 tires?
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 05-06-2014   #105
KILLSHOTS
Agreed, Sumis and Nittos are, in fact, 315 millimeters wide. But put a Z riding on them next to a Z on Goodyears, and the Goodyears look wider. You are correct, it has to do with the shape of the sidewalls, NOT the manufacturer's quoted section width. I have also heard from an extremely reliable source that a Michelin 335 and a Goodyear 315 look nearly identical side by side, which would suggest that the shape of the Michelin's sidewall also makes them appear to run narrow. Illusion or not, it is what it is.
Old 05-06-2014   #106
USAZR1
USAZR1's Avatar
Fwiw,my 335 Nitto NT-05's measure a tad over 13" wide.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 05-06-2014   #107
What is the tread on the ground "footprint" width?
Old 05-06-2014   #108
USAZR1
USAZR1's Avatar
I'm at work now but I'll try to get that measurement,tomorrow.
Clint & Sherry
Old 05-06-2014   #109
8cam
My Nitto 315s are approximately 12.5" sidewall to sidewall, which is also a decent approximation of the dynamic loaded contact patch - the shoulders are rounded for a reason. For these tires the static unloaded contact patch is right at 11" but that really means nothing other than a "look" and for a road/performance tire, they look right. A drag tire will be more square shouldered and will look like more on the ground (but it really isn't). No matter what kind of performance you're looking for, static contact patch doesn't really mean anything.
Hell, 315s are ENORMOUS compared to just about anything out there already! Certainly the widest tire I've ever had on any car, and that's more than 40 different cars. These tires are freakin big.
Black/Gray
Old 05-07-2014   #110
Hog
I think what some of the guys are referring to is the fact that not all 315/35/17 tires have the same actual measurements.
The static treadwidth measurement of one manufacturer may be differnt than another manufactureres even though they both say 315/35/17 on the tires sidewall.
These 17x11 315/35/17's on the 3" wider ZR-1 rearend, sure do make these cars look sexy. The only wider tires of the same generation were the Viper's 335/35/17 with a 17x13" rim on the rear for a 95 Viper. I remember placing my outstretched fingertips on the inner edge of a Viper tire, and the outer tire lip reached my elbow. The $100,000 price tag was even bigger though lol.
Those cars have nothing on a LT5 powered ZR-1 IMO.
peace
Paul
