Old 04-28-2014   #21
emmvette
emmvette's Avatar
Default Re: Does the ZR-1 Require a special tow hook or other towing requirements? ---
Why would the hook stick out farther on a '90? Is the front end different? Please do measure and photo if you don't mind.
emmvette is offline   Reply With Quote
Old 04-28-2014   #22
scottfab
scottfab's Avatar
Originally Posted by alwayscode390 View Post
...snip...
Is there any towing requirements for these vehicles? Should I invest in anything to keep in the car "just in case"?
Thanks ---
there is no need for any special adapters for towing. most truck operators will know this but if they don't you can instruct them to tie on to the main member under the engine and use a 2x4 to block out the strap downward and away from the crossmember.
this prevents the strap from rubbing on the front air dam.
no need to cut holes in the air dam at all.
Scott
Old 04-28-2014   #23
Default ZR-1 Towing Adapter
Originally Posted by ZZZZZR1 View Post
Absolutely love the tow adapter
Makes loading the car in the trailer soooo easy!!!!
Thanks cliff!!!!
See ZR-1 Towing Adapter
Old 04-29-2014   #24
Blue Flame Restorations
I don't think it's a matter of wanting or not wanting to modify the lower air dam. It all depends on what the owner needs and wants.
One of my cars would be a great candidate off the towing adapter. I like the looks of it and wouldn't mind modifying/cutting the center air dam at all for that car.
Thanks for posting, Cliff
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-29-2014   #25
scottfab
scottfab's Avatar
Tow hooks are most definitely a good idea for a few
as is cutting up the air damn.
You could even make them longer with a pointy end
as a style point.
Like chariots of old it may start an arms race.
Seriously NOT the worst mod out there for sure.
Scott
