Old 04-25-2014   #1
tpr60
Default ZR1 prom code chart
Talked my friend into buying a 90 zr1 Tuesday, pretty nice car with 103k miles. It came with an extra prom in the glove box with a code of AUAH8555, I can't find my chart or one on the net site. Is this a 1st design prom or the updated 90 prom? I haven't checked the prom in the car yet but suspect it not OEM. Any one have accesses to a prom chart.
tpr60 is offline   Reply With Quote
Old 04-25-2014   #2
scottfab
scottfab's Avatar
Default Re: ZR1 prom code chart
That AUAH8555 sounds like the stock chip for a 90.
There was a TSB 476503 that updated that chip
to 16163905. The new chip corrected a problem where
the idle would not return to normal fast enough after
coming to a stop.
This was found on some old email from 1999 so
it could be dated now.
Scott
Old 04-25-2014   #3
tpr60
Thanks Scott, I knew about the update but couldn't find my notes. Is there a prom chart available in any of the net posts?
Old 04-25-2014   #4
scottfab
scottfab's Avatar
Can't find a table but that does not mean one does not exist.
There is a poll on who uses what chip. That likely would however not have the granularity you need.
Scott
Old 04-26-2014   #5
WVZR-1
This is as close to a complete PROM ID CHART that I've ever seen. It's from a Tuner Cat Program and the information seems to be consistent with GMSPO information:
There would be no reason to remove it to ID it. The scan ID that's in this chart should be what's displayed on a Tech1 or suitable scanner. Now if it were thought to be a modified PROM then ??
Old 04-26-2014   #6
tpr60
Wow! good chart. THANKS!! I am sure this will come in handy for a lot of others to.
Old 04-29-2014   #7
scottfab
scottfab's Avatar
Attachment 3432
Great find. Very helpful
Scott
