03-29-2014 | #1 |
wideband O2 sensor kit
Is there a wideband O2 sensor kit you all would recommend for our cars
Any and all options are welcome and mentioning draw back of brands on the market are welcome also Dave |
03-29-2014 | #2 |
Re: wideband O2 sensor kit
I'm interested here on this too...
Do W/B sensors help ECM overcome lean condition at throttle tip-in?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
03-29-2014 | #3 |
There are a number of WBO2s available.
I have used the Zeitronix ZT-2 for a number of years. Very reliable. I have a gauge attached which will displays Lambda, AFR, and MAP volts. Also an RPM input and datalogging software. http://www.zeitronix.com/Products/zt2/zt2.shtml Dynamic EFI has one that allows you to program stoich for the fuel being used. http://dynamicefi.com/TT-1.php Do W/B sensors help ECM overcome lean condition at throttle tip-in? No, you need to modify the calibration to do that. The WB is tool to help you in identifying where you may be going lean. From there you can adjust your pump shot otherwise called Acceleration Enrichment (AE) tables.
03-31-2014 | #4 | |
that being said, the WB 02 will help you log what the A/F ratio is during throttle tip in to see what the car is doing which will help with the tune. you can also log with a number of products (Ease, diacom, ect...) to a laptop using the stock ALDL data stream and the narrow band sensors will give you an idea of the AF ratio only problem is with the narrow band sensors they aren't accurate at very rich or lean mixtures (hence the term narrow band)
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
