#21 | |
![]() Join Date: Feb 2011
THE COMBO NOT TO RUN: Wagner Ceramic (Thermoquiets) with $59 Chinese rotors. You can just see one of several cracks at 9-o'clock position: ![]() Plenty of heat checking and hot spots: ![]() This pad could not pass heat thru it and I would recommend a true semi-metallic. the ceramic ran hot- and this was just from street use. I probably ran these all of about 4 months. At least C5 brake parts are 1/2 the cost. ----------------------------------------------------------- My current set up is Hawk HPS with EBC rotors (cast in the UK). The HPS dust, but this combo dissipates heat properly. ![]() |
#22 |
Hey exfire,
Is it to soon to see if you like em,less brake dust,good grip?you said just installed. |
#23 |
Mike,
Wow that's crazy,I think I'll go with hps and look for a high quality rotors.i like your rotors,do they make em without slots? |
#24 |
How'd the exhaust install go there Tomz?
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
#25 | |
Yeah it is a bit too early for a number of reasons: 1. Car is up on jackstands 2. Need to bleed brakes 3. Gotta install eBrake cable setup for the Z06 calipers 4. Still snow on the ground although looks like weather may be warming up pretty soon. I did buy them from someone who had them installed on a Z06. He had switched out the OEM pads for the same reason. Too much dust. I asked about noise and he said these pads did not squeal.
#26 |
Hey schrade,
Haven't started on exhaust yet after brake job,shock install went good,waiting on captain z for actuator,should be Wednesday,then exhaust(will post pics) ![]() |
#27 |
Check out centric pads & rotors from tirerack.com under brakes.looks and sounds high quality.
#28 | |
I think in my case the cheap metallurgy of my rotors was worse than the ceramic pads- or maybe the combination of both. I had run the same Wagner ThermoQuiets on my old 95 LT1 car without issue, but it was on the oem rotor. That car was lighter and less powerful, but also had a weak brake booster and I feel it was just plain easier on the brake temps. The experience I had above kind of put me off on ceramic pads, but I will try again on my C6 as I was able to get all for corners with GM Delco ceramics for $100 shipped on a promotion. The Z51 came with semi-mets, but I only street drive this car...but we'll see. If they also don't work well, I will never buy another set again, but if it works out, I'm calling the issue a cheap rotor metal problem. |
#29 | |
![]() Join Date: Jan 2009
#30 | |
![]() Join Date: Dec 2003
It was more for the asthetics with the Fikses & LPE Aerobody than anything. The PowerSlot/GS Calipers/PerfFric-Z combination worked well for anything I ever did.
Jerry Downey [I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I] [URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL] 1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. |
