03-06-2014 | #11 |
Re: Finished designing and machining the Billet single throttle cable clip
Sign me up for a pair of doubles. -Steve
03-06-2014 | #12 |
03-06-2014 | #13 |
You guys asked for it and I have come thru on the Billet single and double throttle cable clips that replaces the nasty factory clips.
Billet double throttle cable clip.JPG Price will be $40, shipping is included, for the pair whether you choose the single or the double billet throttle cable clip. Thanks for your support and more is on the way from CT Machining...
03-07-2014 | #14 |
Please let me know when the 2 cable clips are available
03-07-2014 | #15 |
Carter, what is your paypal info? I want to order a set of double cable clips.
03-07-2014 | #16 |
RJB48......PM sent
04-04-2014 | #17 |
Just finished a bunch of the ones ordered and will be mailing them out tomorrow (Friday).
GC, I started on your project on Wednesday as promised and all is going well. I'll update you soon. Thanks all for ordering and contact me if you want to upgrade your metal clips to billet clamps. No need to order any bolts or screws as my part uses the original fastner.
04-13-2014 | #18 |
Finished designing and machining the Billet single/double throttle cable clip
Well,
Finished the billet single and double throttle cable clamp. Mailed out the majority of the clamps ordered and just found an issue. Seems that the pads that are on the plenum that the throttle clamps bolt to are NOT the same dimensions. When I designed the billet throttle cable clamps I used my front pad on my LT5 and it fit perfectly. I will be checking the rear pad to see what the difference is. I'll probably have to design a different one for the rear and will do so and will make it right with those whom I have mailed the pair of clamps to already. If you would please mail back the one you do not use I'll reimburse you the shipping cost back to me. Please drop it in a bubble mailer and ship the cheapest way as I do not need the clamp back quickly. Just wanted to give you all heads up that I am working this issue and will have it fixed ASAP.......Thanks, Carter
04-14-2014 | #19 |
Checked my plenum for the throttle cable clamp pad dimensions and they are NOT the same. Also noted that I will change the design to have one locating tab as the weld on the plenum holding the factory pad is causing the second locating pad to not seat on the pad.
I'll have the fix and replacement billet throttle cable clamps done this week for shipment to those who originally ordered and received them. Please return the unused billet throttle clamps to me for a full refund of the shipping cost. Please PM or email me letting me know if you are having to return any clamps and which pad, front or rear, you are needing. Thanks for your understanding on this issue, Carter
04-14-2014 | #20 |
efnfast filed off one locating tab side and it worked fine so if you wanna try that first then let me know if you need a replacement or not that would be fine.
