Old 11-10-2011   #1
Default Coilover kits from Speedway
These look great and seem very reasonable. $42 per wheel.
Old 11-10-2011   #2
Default Re: Coilover kits from Speedway
that is what I am using..
needs a custom part though
Old 11-11-2011   #3
pantera1683
Carter makes the part you need.
Old 11-11-2011   #4
Ring I gave him the info for the parts
Old 03-02-2014   #5
Karl
Karl's Avatar
I found this old thread and am looking into putting together a coil over kit or purchase the DRM unit. It appears putting together the kit will be noticeably less money and with my car having new Blistein fx3 shocks I should be fine.
What parts are needed besides springs and the above mentioned part from speedway (which is now $39.99/wheel) are needed?
Thanks!
Old 03-02-2014   #6
Springs and Contact Carter on this forum for the custom part
Old 03-02-2014   #7
Karl
Karl's Avatar
What is the custom part?
Old 03-03-2014   #8
carter200
carter200's Avatar
Jeff,
You talking about the "coilover hat offset bushings" that I machined for you and others.
Would you please PM pushrod-v8 and tell him about them as you know more about the why's of needing them.
I still have the blueprints to make more. Thanks, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 03-06-2014   #9
cvette98pacecar
Originally Posted by carter200 View Post
Jeff,
Jeff, Give me a call when you have a chance. I am in need to two sets of coil overs.
Old 03-06-2014   #10
I will try to call you later today
