01-23-2014 | #31 | |
Billet Oil Dipstick Handle
You can see if you take a hammer to the plastic "T" Handle you end up with a nice Flat steel end with a dimple that you can drill in the middle. I added washers to seal the deal I just know Carter can make Lemonade out of this without the washers and a better transition from Billet Aluminum "T" Handle to the Dip Stick Several have Oil Dipstick "T" handles that are broken or cracked which is what I had.....so what the hay.....get the hammer out and see what is inside the "T" Handle I NEED Two. See Item #3 of LT5 Lubrication Tricks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-23-2014 at 11:22 PM. |
01-24-2014 | #32 |
Re: Billet Oil Dipstick Handle
[QUOTE=Dynomite;194154]Here ya go ......Etched with AMSOIL 10W-40 in Heavy Red Letters. The size of the letters is shown.
You can see if you take a hammer to the plastic "T" Handle you end up with a nice Flat steel end with a dimple that you can drill in the middle. I added washers to seal the deal I just know Carter can make Lemonade out of this without the washers and a better transition from Billet Aluminum "T" Handle to the Dip Stick Still awaiting the donor dipstick from GC per our last talk about this.......
01-29-2014 | #33 | |
Re: Looking for single throttle cable clips
http://www.classicindustries.com/195.../tf600111.html You can enlarge the image from the link so rather than posting just an image I did the link. I needed some heater cable for a friend and stumbled across these. |
01-29-2014 | #34 | |
[QUOTE=carter200;194161]
03-06-2014 | #35 |
Billet single throttle cable clips
You guys asked for it and I have come thru on the Billet single throttle cable clip that replaces the nasty factory clip. I will be designing and machining the double throttle cable clip tomorrow.
Billet single throttle cable clip.JPG Billet single throttle cable clip old and new - 2.JPG Billet single throttle cable clip old and new - 3.JPG $40, shipping is included, for the pair whether you choose the single or the double billet throttle cable clip. Thanks for your support and more is on the way from CT Machining...
03-06-2014 | #36 |
Billet double throttle cable clips are done
Here is the Billet double throttle cable clip:
Billet double throttle cable clip.JPG $40, shipping is included, for the pair whether you choose the single or the double billet throttle cable clip. Thanks for your support and more is on the way from CT Machining...
95 ZR-1 BLK/Gry #392 LT5 Reg# 868 *RIP* ZR1NET Founding Mem #155 Last edited by carter200; 03-06-2014 at 08:12 PM. |
03-06-2014 | #37 |
Nice, cash is on the way Carter. -Steve
03-13-2014 | #38 |
Now have double and single billet throttle cable clips...
Received your payment. Also have received payment from Dynomite, Crabs, Roy Barnes and HAWAIIZR-1.
Thanks guys for the support. I plan on mailing out next Friday. Contact me if you need them sooner........
95 ZR-1 BLK/Gry #392 LT5 Reg# 868 *RIP* ZR1NET Founding Mem #155 Last edited by carter200; 03-14-2014 at 02:21 AM. |
03-13-2014 | #39 |
Carter,
Settling in back in Hawaii; will send payment soon for 90MY double. Mahalo brah! Craig
03-14-2014 | #40 | |
PS: Welcome back and get well
