#521 |
![]() Join Date: Jan 2012
Received mine yesterday...Very nice! Excellent work!
Jim Zorgias ![]() 1994 ZR-1 Admiral Blue/Black #245 1996 Callaway Supernatural 450 1990 Callaway Supernatural 490 / CR-1 #7 |
#522 |
![]() Join Date: Mar 2007
Thanks everyone, have 7 left but will order more soon
#523 |
PayPaled.......1990 # 072
#524 |
Hey Cliff,
Normally I do 1990 #0072 .....instead of 072 Is that ok?
#525 | |
Normally I do a lot of ZR-1/LT5 modifications but on this 90' especially since it is one of the first off the assembly line (and only 38,000 miles).... No modifications.......Except some Carter Bling and your Map Sensor Cover.......and RC SL4-205 Injectors ![]() Added the Billet Aluminum Belt Tensioner Pulley and did the standard Dynomite Top End Restoration including Starter Solenoid ![]() Remove Plenum and clean Valley drain, fix ALL vacuum leaks including check valve on passenger side under Plenum, block TB Coolant at Injector Housing and often replace Injectors. Requires New Plenum Gasket from Jerry. Changed ALL fluids.......AMSOIL 10W-40 Engine, CASTROL 10W-60 Transmission, Mobile 1 75W-90 Differential and some NAPA Green antifreeze. ![]() And since changing out Differential Fluid...added the 1/8 inch NPT Allen Drain Plug. Lee.......installed the 1990 #0072 today.....looks superb as that is the only visible modification to this LT5/ZR-1 ![]() The LT5 runs soooooo smooth.......just installed new Clutch Master and Clutch Slave from Jerry. Also replaced all four speaker amps with 95 Nissan Max amps for a perfect sounding Bose System. ![]() ![]() Have South Dakota Plates (UWLNTWN) on the way.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-26-2015 at 10:41 AM. |
#526 |
Need a 1990 #3032
Let me know if you have any left ![]() |
#527 |
![]() Join Date: Mar 2006
I'd like one also if you still offer these.
1991 #988 I'll take two if you have enough 1995 #069 Let me know about payment. Thanks, Randy Last edited by randy ransome; 05-24-2014 at 10:34 AM. |
#528 |
Let me check I think I have enough, time to reorder....
If anyone else wants one let me know so I know how many to order
#529 |
![]() Join Date: Apr 2004
Yes one more
1993 # 179
#530 |
1990 3032 1991 0988 All done ....paypal is leegaffigan@yahoo.com Thanks Be sure to send the correct address I am officially out of MAP sensor covers
