Old 12-27-2013   #1
pantera1683
Default Shock rebuild questions
I have some extra shocks (front and rear) I want to have rebuilt and revalved. Is it possible to powdercoat them before I send them to Bilstein and where can I get new rubber or poly bushings for them?
Old 12-27-2013   #2
Default Re: Shock rebuild questions
Sure but what if the shocks you send to them are not in a rebuildable by Bilstein condition? I think that is unlikely but it's a possibility. Also during tear down its possible the coating also could become damaged during the process. Just some thoughts
DRM used to carry the bushings if not I'm sure Bilstein does. GC
Old 12-27-2013   #3
pantera1683
Also during tear down its possible the coating also could become damaged during the process. GC
I thought about that too, but Bilstein doesn't paint them, they just apply new stickers-looks pretty silly on old dirty shocks.
Old 12-27-2013   #4
Jagdpanzer
Jagdpanzer's Avatar
Something to think about. During the powder coat process the shocks will see 400 degrees F in the oven to cure the resin. To be safe I would fully disassemble first.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-27-2013   #5
pantera1683
Wow, in that case maybe painting would be better!
Old 12-27-2013   #6
I agree and your not saving that much on the rebuild. I only like the rebuild idea if your going with a moracca or senza valving to help in auto crossing.
Old 12-27-2013   #7
pantera1683
Is the Moracca valving only good for autocrossing? I want a stiffer valving to go with my coilovers.
Old 12-27-2013   #8
Yes it is
Old 12-28-2013   #9
Coupe89
Yep very stiff... haven't tried performance yet...
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 12-28-2013   #10
