Old 12-08-2013   #1
Okiedoke
Okiedoke's Avatar
Default Rattling/vibration from the rear
When driving the Z, sometimes there's this metallic rattling or vibration coming from the rear of the car. This tends to happen when I'm in first gear, drag out the shifting, or shift to too high a gear (low RPM). Does anyone have any ideas on what might be causing this?
1991 ZR-1 #405 (white/black with blue pin stripes)
Okiedoke is offline   Reply With Quote
Old 12-08-2013   #2
edram454
edram454's Avatar
Default Re: Rattling/vibration from the rear
maybe your back window. I had a 1992 that made noise in the back and it was the hard top I had in the rear wasnt clipped on correctly. probably when you are in first gear it makes just the right amount of vibration that causes that rattle. check back window.
edramos.
Old 12-08-2013   #3
Schrade
It is said that early shifting, and allowing the engine to lug, transmits vibration through the DMF, and will break it.
Whether or not this is what you're getting, I wouldn't know here...
Old 12-08-2013   #4
edramos.
Similar thing happened to me but it was my Top not secured like it should have been when installed (not stored)
Or............exhaust hangers in rear loose or exhaust rattling against differential.
Old 12-08-2013   #5
Yep, I would check the exhaust or a heat shield.
